Super V - Bass?
0 Members and 1 Guest are viewing this topic. Read 7679 times.
JDUBS
Re: Super V - Bass?
« Reply #20 on: 1 Aug 2011, 05:35 pm »
Danny,
-The max output is typically quoted at 1m.  If you don't have this info, that's fine.  I'll assume 105db is the max.
-97db is not that high...how about 111db horns?  Can it match those?  My guess is no and that software gain will need to be applied.
-All my amps have gain quoted in db.  My F3 is at 13db and my K2 is at 32.88db
-Jim
That will really depend on room size and listening distance.
Not really relevant as you have your own volume control on the amp. So it can easily match anything by turning a knob. It even easily matches the 97db sensitivity of the Super-V.
By the numbers though, a pair of the woofers will be 90.7db sensitivity via 1 watt/1 meter.
Amp gain can be measured by voltage.
FYI, at RMAF a few years ago a pair of Super-V's was easily hitting a measured 105 peak durning music play back. It also did this all the way down to the rock bottom.
Danny Richie
Re: Super V - Bass?
« Reply #21 on: 1 Aug 2011, 07:21 pm »
That measured 105db level was what we were getting as an in room response about 12 feet away from the speakers. I think the servo amps were turning up to about a 1 o'clock setting. So they had some head room to spare.
You can also run three of these woofers on one amp and get 1/3rd more output again with the same amp.
I have little doubt that they will keep up with any of your horn designs. Regardless of the output capability of some of the horn designs, I doubt anyone will really listen at those levels.
The 97db sensitivity of the Super-V drivers are also rated to handle 400 watts continuous. Regardless of high loud they might really play, no one is going to listen that loud.
JDUBS
Re: Super V - Bass?
« Reply #22 on: 2 Aug 2011, 03:41 am »
Fair enough on all points, Danny.  How would you construct an ob 3-driver / side setup?
I like that you can run 3 of these off the same amp!  I like headroom...
Jim
HT cOz
Re: Super V - Bass?
« Reply #23 on: 2 Aug 2011, 04:40 am »
I think there is a 600w amp also available that will work with 3/side?
Danny Richie
Re: Super V - Bass?
« Reply #24 on: 2 Aug 2011, 02:44 pm »
You won't need that much power on them.
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
Re: Super V - Bass?
« Reply #25 on: 2 Aug 2011, 08:20 pm »
I think the limit is the xmax, so more power doesn't do anything for you.
JDUBS
Re: Super V - Bass?
« Reply #26 on: 3 Aug 2011, 09:38 pm »
Ok, I'm going to give this a shot.  Will start off with 2 woofers per side in an h-fram ob with the xlr version of the servo amp, the A370-XLR (Danny, do you stock this one or do I need to go through Rythmik?).
The xlr version of the amp will allow me to slave an additional amp / woofers if I want to.
Looking forward to it!
-Jim
Danny Richie
Re: Super V - Bass?
« Reply #27 on: 3 Aug 2011, 09:47 pm »
-Jim
I can get you the XLR amps, no problem. You can even go on line and order it all from our web site. Just put in the comments section of the order that you'd like the XLR amps and I will see that those are the ones that you get.
JDUBS
Re: Super V - Bass?
« Reply #28 on: 3 Aug 2011, 10:13 pm »
Thanks Danny.  Should I do the w-frame or h-frame if I want to get to 300hz?  I'm willing to do either.
-Jim
Danny Richie
Re: Super V - Bass?
« Reply #29 on: 3 Aug 2011, 10:59 pm »
I liked the H frame best myself.
ebag4
Re: Super V - Bass?
« Reply #30 on: 3 Aug 2011, 11:44 pm »
-Jim
You're going to love it! :thumb:  Good luck with the build.
Best,
Ed
Rocket_Ronny
    • ScriptureSongs.com
Re: Super V - Bass?
« Reply #31 on: 4 Aug 2011, 12:30 pm »
Danny:
Can you share the sonic differences between the W and H frames, and to what degree?
Rocket_Ronny
Danny Richie
Re: Super V - Bass?
« Reply #32 on: 4 Aug 2011, 02:34 pm »
The W frame left larger panel areas between braces (or between the W) and was more resonant. The H frame divided the box into smaller panels that were less resonant.
jtwrace
    • TIPP YouTube Channel
Re: Super V - Bass?
« Reply #33 on: 17 Aug 2011, 01:26 pm »
-Jim
Any progress on these?
JDUBS
Re: Super V - Bass?
« Reply #34 on: 18 Aug 2011, 01:31 am »
Yes.  They (the woofer and amps) are on their way to my builder, Roman.  Will post again when they are set up.  Roman will also be fixing up my Unity horns (they need to be finished and painted).
-Jim
face
Re: Super V - Bass?
« Reply #35 on: 19 Aug 2011, 12:05 am »
Do you have a schematic you could post?
JDUBS
Re: Super V - Bass?
« Reply #36 on: 19 Aug 2011, 12:13 am »
face
Re: Super V - Bass?
« Reply #37 on: 19 Aug 2011, 12:21 am »
