which 2011 mac mini?
0 Members and 1 Guest are viewing this topic. Read 10948 times.
wgscott
Re: which 2011 mac mini?
« Reply #20 on: 15 Aug 2011, 03:41 pm »
Here is a nice, free, unobtrusive temperature monitor:
http://www.bresink.com/osx/TemperatureMonitor.html
This guy writes extremely high-quality software.
naggots
« Reply #21 on: 15 Aug 2011, 10:45 pm »
I'm a newcomer to computer audio, previously had a Wadia transport and 80gb iPod with WAVs feeding a W4S dac1......
Sold them and bought a John Kenny DAC and the new Mac mini, 2.7 i7, 8gb ram. ....... Had to re rip all my CDs after spending a week trying to transfer itunes from my macbookpro/windowsXP...... So purchased the superdrive...... Re ripped everything in aiff to keep metadata....... So after 10days I now am hearing music properly. I use Bitperfect 2.9 but will try Audirvana.
The sound is better than I've ever had...... Much better....... The wadia combo was great for 2 yrs but this is in a different league.........warm, detailed, airy with deep tight bass..... Not digitally or sharp as before........
I don't notice it running warm at all, no drop outs or clicks yet
JohnR
« Reply #22 on: 16 Aug 2011, 01:26 am »
Thanks but... I don't need one ;)
wgscott
« Reply #23 on: 16 Aug 2011, 03:30 am »
Lucky you.
JohnR
« Reply #24 on: 16 Aug 2011, 04:01 am »
Here's someone that reckons that the temperature goes back down after a few days:
http://gigaom.com/apple/is-your-mac-running-hot-with-lion-heres-why/
I have spotlight turned off.
Also there's a link to something you can use to manually set the fan speed.
wgscott
« Reply #25 on: 16 Aug 2011, 06:12 am »
That's interesting.  Spotlight (when it is turned on) should only take a few hours, but clearly there is more going on, if it takes five days.  (I've heard the new whole disk encryption takes a long time, but as far as I know, I am not doing that.)  Several people have claimed 10.7 needs to break in, which I thought sounded nutty, but maybe there is something to it.
The bit about the processors automatically slowing or stopping to prevent overheating could easily account for what is going on in terms of sound quality. It would also explain why people using macs with the Sandy Bridge processors appear not to have this issue.
Good find!
JohnR
« Reply #26 on: 16 Aug 2011, 12:55 pm »
I suppose that's why dedicated devices like the Bryston BDP-1 (and I think I read about some others recently, although I don't recall model numbers) make sense.
wgscott
« Reply #27 on: 16 Aug 2011, 02:17 pm »
£2.2K   That's almost $2K, using the Apple Store's currency converter.  Takes the fun out of it, too.
JohnR
« Reply #28 on: 16 Aug 2011, 02:24 pm »
All I'm saying is that there is a reason :)
gprro
« Reply #29 on: 17 Aug 2011, 04:44 am »
Anyone think a 2010 might still be better, considering it runs leopard well? Or stick with the 2011 and figure they will figure it out. The mach2 guys have leopard running on their 11's, but I'm hoping they'll figure a way to tweek lion.  I just bought an '11 but have until fri. to return it...
wgscott
« Reply #30 on: 18 Aug 2011, 03:16 pm »
I just brought home a 2011 mini from work and compared it to my 2010 mini.
Briefly, the 2011 mini running 10.7.1 works absolutely fine, doesn't run hot, and to my ears sounds identical to my 2010 mini running 10.6.8.  I only compared rebook lossless via iTunes, but the main point was to check to see if there were any obvious deficiencies.  I didn't have time to do an extensive comparison, but it appears to work fine.  If I buy one for myself, I wouldn't bother putting 10.6.8 on it.  (In fact, I created a second partition with the intent of doing just that, and put briefly, I never was able to do it.  Others have reported problems with 10.6.8 on the 2011 mini, so probably this is not a good idea).
gprro
« Reply #31 on: 19 Aug 2011, 02:43 am »
Had an email exchange with Eric from db labs, with his minor tweaks he still prefers the '11 with lion. With iTunes having a noticeable improvement, maybe due to running in true 64 bit now. Admitidly though he agrees the mach2 guys using leopard probably works better because they can strip away so much  more back ground code from leopard. Hopefully they can get there with lion as well. So lightly tweaked lion 11 beats a leopard 10, but the fully rewritten 11 running leopard is the best I guess.
JohnR
« Reply #32 on: 22 Aug 2011, 12:48 pm »
Interesting to hear. Thanks for the update  :thumb: Curious that the earlier hardware would have such an issue.
wgscott
« Reply #33 on: 22 Aug 2011, 02:23 pm »
I didn't "stress-test" it by compiling something that used both processors to the max, for example.  But in the typical low-CPU-demand setting, it seemed perfectly fine for audio.
jrebman
« Reply #34 on: 24 Aug 2011, 02:07 am »
So, hate to ask a stupid question, but which are the Sandy Bridge processors?  Are these in the minis?
So much conflicting data on the 2011s, Lion on the 2010s, etc., wish I could find a real definitive answer as to whether the 2011 running PM is indeed better or at least equivalent to the 2010 with PM, though for now I'm betting that my Mach2 2010 with PM is still the best choice (obviously with snow leopard).
-- Jim
jtwrace
    • TIPP YouTube Channel
« Reply #35 on: 24 Aug 2011, 02:11 am »
You could just buy this and be done.
http://www.audiocircle.com/index.php?topic=97823.0
JohnR
« Reply #36 on: 24 Aug 2011, 02:13 am »
It's the latest processor from Intel, released this year. The 2011 mini has it, I assume the most recent model iMac and powerbooks do too.
jrebman
« Reply #37 on: 24 Aug 2011, 02:26 am »
Jason,
Thanks, but why would I want to take a step back from my 2010 mach2 mini with 8 gb ram?
Thanks, John.
-- Jim
jtwrace
« Reply #38 on: 24 Aug 2011, 02:30 am »
Jason,
Thanks, John.
-- Jim
 :oops:  Missed that.  Sorry.
Crimson
« Reply #39 on: 24 Aug 2011, 04:31 am »
Newer is better.  :P
Isn't that always the case?
