0 Members and 1 Guest are viewing this topic. Read 10927 times.
Thank you for your replies. My main concern is choosing between the 2011 models. If the base model can play high def video (blue ray files, etc) without any problems, then I'll go with that, but if I have to go with the 2.5GHz (or i7) model, I want to make sure that the audio part will not be compromised.
Here's the question, though: Is there any reason to think that the 2011 Mac Mini config with the 2.5GHz i5 and AMD Radeon HD 6630M graphics would be sonically superior as a music server (probably by virtue of not having to share video RAM) to the base configuration, which is 2.3 GHz and graphics via the Intel HD Graphics 3000? The difference is only $200, some of which is for the RAM bump from 2GB to 4GB, which I won't use anyway, but $200 is $200.
I mean, what are the people saying Lion doesn't do audio well going to be doing in five years time, still running 10.6 on their 6-year old computers?
Wgscott, I hope these problems are being communicated to Apple, either by you or others. It's alarming to think that the new OS renders a recent Mac unable to play back music, which I don't think is all that taxing, and rub its stomach at the same time. Would you say your problems with Lion and music server use are mainly about what one might call "performance" (interrupts, pops, clicks) or are you also experiencing sound quality degradation apart from performance issues?
