0 Members and 1 Guest are viewing this topic. Read 16245 times.
kinda like the stock felt baffling on my meret re's. tho a bit difficult to see in the foto, the felt is tapered 45 degrees at the drivers...doug s.
how can it be a low pass filter when i have cut holes for the drivers? I would think it not be doing anything other than absorbing cabinet reflected sound and cabinet talk, both of which are not desirable My system already has fairly good imaging and now it has better imaging. I have also noticed an improvment in the clairity of the high end... which seems to be the result of the removal of this extra imformation that would be blurring the sound. audioengr would you please explain your idea more! and doug s, i have only applied 2mm of felt not thick felt like in these examples, i have also cut reasonable holes around the drives so as to ensure minimal interferance. I just noticed i failed to mention that my drivers are not recessed and that the felt makes them pretty much flush now. (im sure this is a big factor!)
