Is there an inexpensive way to rip LP's
0 Members and 1 Guest are viewing this topic. Read 4696 times.
Chromisdesigns
  • Darla, our beach cat, contemplating the sea
    • Fine-gemstones.com
Re: Is there an inexpensive way to rip LP's
« Reply #20 on: 1 Aug 2011, 06:47 pm »
doesn't rip to flac. only to wav or mp3. Yes, big drawback. But if you have a conversion program like dbpoweramp you can do a "batch" conversion of all your files when you are done.
But it was said that one of the big pluses to SpinItAgain was ability to split tracks and tag -- wouldn't you lose that ripping to .wav?  Or does it make a bunch of track-sized named .wav files you could later combine into a useable FLAC?
mjock3
« Reply #21 on: 2 Aug 2011, 12:35 am »
Well I bought the UFO202. I got it today, I downloaded Spin it again, and it says it is not hearing anything. Anyone out there have a UFO202? Do you have gain problems? I am running it through the preamp built in because my Phono preamp is down right now.
Mark
« Last Edit: 2 Aug 2011, 01:16 pm by mjock3 »
Chromisdesigns
« Reply #22 on: 2 Aug 2011, 02:20 am »
Well I bought the UFO202. I got it today, I downloaded Spin it again, and it says it is not hearing anything. Anyone out there have a UFO202? Do you have gain problems? I am running it through the preamp built in because my Phono preamp is down right not.
Mark
Got one coming in a few days -- if you figure out a solution, please post it!
Bob
mjock3
« Reply #23 on: 2 Aug 2011, 01:46 pm »
Bob,
Have not figured the Spin it situation, but I got it running on Audacity. Recording at low levels. Which can be fixed via Audacity in affects (amplify). Still need to do some tweaking, I think I amplified it too much and am having some distortion in louder passages.
Mark
