Chime high voltages
0 Members and 1 Guest are viewing this topic. Read 1124 times.
fandersen
Chime high voltages
« on: 19 Jul 2011, 03:54 am »
I finished assembling my chime and started checking the voltages.
With no tubes I get 7.97 for the Hagdac, which is good.
With only the rectifier (Sovtek 5Y3GT) installed H+ is 8.57 and B+ is 380. I did try a Sovtek 5AR4 from my Cornet just in case the tube was faulty, but same voltages.
I checked the voltage across R103 and I get 6.56 VAC.
The voltage at R438 is 368v, not the 305v shown on the board.
Any ideas why the voltages are so high?
Flemming
fandersen
Re: Chime high voltages
« Reply #1 on: 19 Jul 2011, 04:12 am »
So putting in the rest of the tubes brings the voltages in line :duh:
I now get 5.78v at H+ and 298v at R438.
