rogue 88 tube rolling question
0 Members and 1 Guest are viewing this topic. Read 1224 times.
usp1
« on: 18 Jul 2011, 07:59 pm »
The Rogue 88 has (4) kt-88, (4)12au7 and (2) 12ax7 tubes. I was wondering which if the three tubes would have the most effect if I tube rolled.
hibuckhobby
  • On a search for audio nirvana
Re: rogue 88 tube rolling question
« Reply #1 on: 18 Jul 2011, 09:40 pm »
My experience is that the 12AX7's and then the AU's changed the sound more than different KT88's.   What are you trying to change about the sound?
Hibuck....
usp1
« Reply #2 on: 18 Jul 2011, 09:43 pm »
Just wanted to experiment. Since there are (2) 12ax7 versus (4) 12au7 it would be a lot cheaper to follow your advice... :)
