0 Members and 2 Guests are viewing this topic. Read 39562 times.
All I have to say is good luck fitting those monsters in a TWO.2 chassis!
I am happy to report that the break in is coming along nicely. Most of the brightness has gone and a much smoother more extended treble is emerging. The sound of the M901 with the auricaps was slightly warm with big bass and smooth highs that were slightly rolled off,a very pleasant inviting sound. With the clarity mr caps the sound now has more drive to it with deeper tighter bass. The mids are very neutral,but not cold,with a much greater clarity. The treble is now more open and airy with great extension. The sound has really come to life with a density of information and spacial cues that had been supressed with the auricaps. The sound from my speakers pretty much filled the room before this upgrade but now it has made my walls disappear with sound that surrounds me seemingly coming from a room away. The opening to Avatar has a strong drum strike that really sets the mood. This drum stroke rolled through the room from front to back before but now it sounds like I am in a vast open space when that stroke hits and it rolls past with more authority and more clearly defined. I felt that the sound with the auricaps was balanced toward the lower midrange and softened at the low bass and upper treble. The clarity mr caps seem to be giving a completely balanced range from top to bottom. This additional range makes the amp sound more dynamic and more live. The initial brightness is being replaced with a more real sounding metalic bite to cymbals. All of the sounds that used to lurk in the back of the mix or that were almost totally obscured are now brought out to hear more clearly. The best way that I can sum it up is that the sound is vibrant and full with so much densely packed information and spacial cues that I am hearing familiar music and movies in a totally different way.I have to say that I am a bit shocked by the difference in sound between yesterday at 7pm when I listened to Bluetech's Sines and Singularities and when I listened to it this morning at 11am. The sound has really opened up and smoothed out while exposing more of the hidden sounds in the mix. If you can't tell by now I am very satisfied with this upgrade and can't wait to hear what the amp sounds like in a few more days.
And for those wondering, my room is 14'X19'X9' with a door at the back left of the speakers that can be opened to act like a bass trap and very large pocket doors on the opposite wall just ahead of the right speaker. The house is 100 years old so the walls are plaster and lathe with the original wallpaper that looks and feels like silk which I think has a lot to do with the great sonics of this room.
What tube are you running? You might have mentioned it.
Perhaps a crazy reckless thought but can one do this cap upgrade oneself? The hassle and expense of shipping from Canada and being without tunes for a couple of weeks makes me hesitate.
