0 Members and 1 Guest are viewing this topic. Read 22899 times.
What are those two things on top of the rack? Charlie
I don't know if anyone else noticed, but Fritz has his own line of speakers yet he was nice enough to post the pictures here. Cosmically good manners, thanks Fritz.
What brand of rack is that?
We built that rack expressly for use at this show. So I guess you could say it is a SalkRack.- Jim
The closest comparable device is the Bryston BDP1 ($2700)
Doesn't change the value of the StreamPlayer at $1295, but the Bryston BDP-1 is $2195. Steve
Seems you need more information
1. The stream server appears to be based on Vortexbox. This picture sums things up:http://www.audiocircle.com/image.php?id=42106
2. The stream player appears to be based on the Alix project.Here is a pic taken from a CA post of the pair. The left unit is the stream player:http://images.computeraudiophile.com/graphics/2011/0720/100px/horizontal/IMG_2318.jpgHere is the alix board:http://pcengines.ch/pic/alix2d2.jpgSame board!
The alix board uses a CF flash drive. You said it does not use an ssd or hdd. You should know that a CF flash drive is an ssd.
3. You need to do some research before you say things. The Bryson http://bryston.com/pdfs/09/Bryston_BDP1_LITERATURE.pdf is a one box solution also based on an alix board. That is where the similarities end. It has a remote control,
custom linear power supply,
24/192 aes/ebu and spdif ouput,
control buttons on the face.
IMO it's not close or comparable.
BTW it says Auraliti at the bottom.
4. Ripping noise both acoustic and eletrical are a mute point when it's not ripping.
5. According to your definition of what is good. Vortexbox streaming over the network to a $299 Logitech Touch http://www.logitech.com/en-us/speakers-audio/wireless-music-systems/devices/5745would provide spdif and analog output.
