0 Members and 1 Guest are viewing this topic. Read 10231 times.
J,> Seems like if the recess in the room is small enough it should begin to act as a bass trap <What recess? A recess is not a bass trap. Unless it's packed full with fiberglass or an equivalent material.--Ethan
Sat,> So the recess's in a Real Trap <You have lost me completely. What recess? I designed the MiniTrap and there's no recess I know of! --Ethan
8th: So your products only address low frequencies, right?
O.K. 8th, still confused...But if high frequency sound waves act more like low powered laser beams (reflecting sound) ...
In many of our installations for customers with overly dead rooms, our products will actually increase the high frequency output overall, while reducing echo and distortion....
Most rooms can barely pull off a flat response at 16K much less 20K or higher. By eliminating a large portion of the 90 degree angles in the room, you eliminate the bad high-frequency energy, namely echo and distortion.
No offense but...discussing 8th Nerve's product philosophy sounds like a great topic for a new thread. I just wanted to know what constitues a diffusor - is it JUST the shape or is it the shape + material? Does a chunk of foam really care which way its cut or what? That's all I ever wanted to know on this matter. Thanks!
Thanks for the reply.Yes, I used the phrase "act more like" understanding that high frequency sound waves don't simply/perfectly beam.Could you share how the room pillows help with echo and distortion?And could you explain why you wouldn't want absorption at first reflection points?thanks again
How can the "room" affect the ability of a "speaker" to reproduce a frequency, if nothing is between the speaker and the listener,
except for phase cancellations caused by reflected sound?
Employing out of phase "reflected" high frequencies cannot be a goal to accurate reproduction. It would seem to stand to reason that reducing the "out of phase cancell ...
