0 Members and 1 Guest are viewing this topic. Read 3801 times.
They are less efficient and don't go as low as the ST's, but they have the same wonderful midrange that Jim's speakers are famous for.
The Songbirds will be a major improvement over the Studios. And easy to resell if you want to move up. KEEP THE BOXES!!!!!
The only issue with the SB's is limited power handling in the bass. That's inevitable given that the 5.5" woofer is tuned quite low in the TL cabinet. I've heard others say that the SB's image even better than the ST's. I, of course, only got to listen in mono, so I wouldn't know. I'm currently working on the RAAL version of the SB, which I expect to be a really refined speaker for smaller spaces.
Aren't you tempted to go with a 7 inch woofer on a 2-way RAAL based system? Or are you using a smaller RAAL tweeter that won't cross over low enough to go with a 7 inch woofer?
As to loudness level ... do you think the Songbirds would match the Studio-20s?The Studios is a 2-way, with a 7" Bass driver.I'm not a speaker expert but I was concerned that, given the smaller 5" driver in the Songbirds, they couldn't move as much air and therefore wouldn't handle large peak signals as well as the Studios.Just trying to get a handle on the tradeoffs between the two.Rob
Well, that would be an HT1 RAAL. I guess we'll have to do one of those as well. But this is the Song Bird. I'm using the same RAAL as on all the other Salk speakers. I've had the SB RAAL up and running for a few days, and I'm not sure the power handling is all that big an issue. It's what I would expect from a 5 inch woofer, and what others would expect as well, I think. I think the bird tweets very nicely. I wish I had a pair in my office.
