Matching surrounds to N3S Speakers
0 Members and 1 Guest are viewing this topic. Read 6409 times.
Re: Matching surrounds to N3S Speakers
« Reply #20 on: 30 Sep 2011, 03:28 pm »
You take all of the bracing that makes the TL and flip flop them all to make the exit out the front. Or you could look at it as flip flopping all of the drivers to the other side of the box. Same thing...
So the top baffle which is currently under the lower driver would now be on the opposite/back side in relation to the lower driver?
Danny Richie
« Reply #21 on: 30 Sep 2011, 03:54 pm »
If you are looking at the first page of cabinet plans (via the web site), then instead of the drivers mounting on the left side of the box (side profile), they are mounted on the right side of the box.
Brace A (at the top of the box) moves to the other side as well.
You also move the tube connectors to the opposite side of the box too.
Outofthewoods
  • Fallen Enclosures, Inc. Crafted with Passion
« Reply #22 on: 30 Sep 2011, 03:57 pm »
Looks like this when done! :thumb:
Ruben
Danny Richie
« Reply #23 on: 30 Sep 2011, 04:07 pm »
Thanks Ruben!
Some have even made a little grill (grill cloth) to fit over the opening.
Outofthewoods
« Reply #24 on: 3 Oct 2011, 07:11 pm »
And here's an example of that. :thumb:
Ruben
wndrmke
« Reply #25 on: 4 Oct 2011, 03:24 am »
Ruben,
Is this your handiwork?
[/quote]
Outofthewoods
« Reply #26 on: 4 Oct 2011, 03:33 am »
Ruben,
It isn't.
I can't remember who it was that built those ones. :scratch:
Ruben
django11
  • Canuckistani
« Reply #27 on: 20 Oct 2011, 12:59 am »
Ruben,
He didn't make them but he could... probably with one hand behind his back...
