Parasound HCA 1200 II in Atlanta area $400
0 Members and 1 Guest are viewing this topic. Read 2050 times.
WolfsongAudio
« on: 12 Jul 2011, 02:10 pm »
Here is a Parasound HCA 1200 Mark II power amplifier. Please see the photos for the cosmetic condition. The lines across the top edge of the faceplate are the only noticeable marks. see photo 3. the Parasound website lists the wattage output:
205 watts RMS x 2, 20 Hz-20 kHz, 8 Ω
315 watts RMS x 2, 20 Hz-20 kHz, 4 Ω
Continuous Power Output - Mono
625 watts RMS, 20 Hz-20 kHz, 8 Ω
The amp has adjustable gain for each channel and enough power and real control for almost any speakers.
I will answer any pertinent questions.
This is a used power amplifier and carries NO warranty of any kind. It will not arrive DOA because it works.
Local pick up is OK. If you are local I will even bring it to you.
The amp will weigh in at 42 lbs boxed. Original packing is not included but the amp will be properly packed for safe transport.
Paypal users will pay the 2.9% fees they charge me. I much prefer MO or checks ( after they clear).
WolfsongAudio
Re: Parasound HCA 1200 II in Atlanta area $400
« Reply #1 on: 21 Jul 2011, 07:35 pm »
bump
