0 Members and 1 Guest are viewing this topic. Read 24734 times.
Just a quick note to clarify things... Our StreamPlayer is compatible with any USB DAC or device at bit rates up to 24/96. Above that bit rate, it is compatible with all USB Class 2 Audio devices which are designed to play higher bit rates. No proprietary device drivers are required for these devices.Devices such as the Kingrex UC192 and many USB DACs do not meet USB Class 2 audio standards. These devices require proprietary drivers to play files above 24/96. According to their web site, "KingRex supports proprietary drivers for Windows & Mac." USB audio class 2 was developed in order to address the limitations of the USB standard where the transfer requirements for high resolution audio files are concerned. Devices complying with this new standard do not require special proprietary drivers in order to perform at their maximum rated speed, regardless of the operating system involved. - Jim
How would the SalkStream compare to the Squeezebox Touch?
what is needed to control music through an iphone, pad or pc?
The Squeezbox Touch has a DAC built in with analog RCA out, a display with an interface, is based on ARM architecture chip and, if I remember correctly, needs Squeezebox Server ( http://en.wikipedia.org/wiki/Squeezebox_Server) installed to play music across a network. In stock form, the SB Touch will not feed a USB DAC.The SalkStream is based on a small x86 single board computer running a headless (no VGA, no screen or LCD), stripped down version of Linux. The Salkstream software and hardware is a very minimalist, high performance music server for feeding USB DACs. If the DAC is USB Audio Class 2 (UAC2) compliant it will play 24 bit audio with sample rates to 192Khz. Salkstream is completely silent and has no moving parts. Audio files (FLAC, WAV, AIFF, etc) are fetched over the network via ethernet. You can have a small NAS in another room, use your desktop as a NFS or CIFS server in another room or use JIm's SalkStream server....
the Touch does have digital optical and digital coax output for a DAC
I'm guessing it only supports sample rates up to 24 bit / 96 kHz.
It sounds like it doesn't require a server as you can plug in a USB stick or memory card with music and it will read off that.
nyc_paramedic:Does the iPad interact with the Salk Streamer wireless?
Out of curiosity, are there any alternative boxes offering same functionality?
Jim,I have a BDP-1 and I am really enjoying it.I would be happy to compare and contrast your offering with the BDP-1 if you are interested.George
The only issue with that is that the BDA-1 is limited on its USB input vs. some other things out there. So if that is what you are using you will likely just be able to compare CD quality
Can the Salkstream player be configured with SPDIF out or is it USB out only? If you did not have a USB DAC, as it stands, you would need a USB to SPDIF converter. Is this right?
I have fairly easy access to an Antelope Zodiac + or Zodiac Gold DAC's if needed.George
