For Jim - Cornet/Octal Constant Current Sink Question
0 Members and 1 Guest are viewing this topic. Read 2768 times.
TChung
Jim,
I have built the Cornet Octal and installed the Constant Current Sink option.  I just happened to find out from the recent Cornet manual that the CCS is included in the Schematics and an extra 220 ohm is added.  I am using two 510 ohms resistors now and do I need to add the extra 220 ohms resistor?
Tom Chung
hagtech
    • http://www.hagtech.com
« Reply #1 on: 12 Apr 2004, 06:18 am »
No, you do not need the extra 220 ohm resistor.  That was added merely for the sake of layout convenience.  There were some traces I needed to cross and didn't want to break the ground plane.  Think of it as a jumper.
jh :)
TChung
« Reply #2 on: 12 Apr 2004, 12:22 pm »
Tom
