0 Members and 1 Guest are viewing this topic. Read 17420 times.
As a bonus, the remotes they give you are about the sweetest you'll ever see. I always say they look like they'd fit on the bridge of the Enterprize. Hefty, brushed metal, no plastic anywhere, even the buttons are metal. They are nice, no doubt about it.I also own the XDA-1 DAC and I have to admit I really enjoy the combo. I will probably end up buying their XSP-1 preamp (their uber-reference model) when it launches in a few months and connect all three via AES/EBU as all three units including the ERC-2 have balanced outputs/inputs.
As far as how I will connect the balanced system, I believe you are correct. Looking forward to upgrading from this plastic optical cable I'm currently using. Can you suggest a good bang for the buck AES/EBU?
Does the ER2 compare favorably to the Virtue Audio Piano M1?
The Piano M1 is a much better player .....
The Piano M1 is a much better player, I would think you might be taking a backward step if you sell the Piano and go with the Emotiva MWG. But hey I could be wrong.
I have the XDA-1 in my secondary basement system and am very impressed with the sound quality and build quality for a DAC that cost me $299. I am feeding SACD from a Monoprice (under $44) HDMI de-embedder from an old Oppo DV980H and the sound quality is excellent.
You and me got the intro price They are actually $399 now.
