0 Members and 1 Guest are viewing this topic. Read 21182 times.
Also these speakers are pretty old, and probably need power supply rebuild. I had to change the cap in my F81 due to leakage. F81 and F83 are pretty rare in the US. But I think the ESL57 is better balanced because it is a 3 way and have separated bass panel than other full range ESL, you can still be able to find a pair or two for stacked at reasonably cost. My stacked Quad including the stand that I build cost me less than $3000, which I considered a great buy.
I prefer the stacked Quad because it excel the single in many area: Dynamic, soundstage, depth.... With a sub cross at 100Hz and extra tweeters covering 8Khz up, it transform the ESL57 into a new dimension. Somehow I was pretty lucky, I did not have to rebuild the power supply on all 4. It is a pretty time consuming process.Another long shot to improve the speaker is to build two direct coupled tube amplifiers for the bass/tweeter panel with active crossover to drive them directly.
