Help with first hi-res download...
0 Members and 1 Guest are viewing this topic. Read 1181 times.
rtate
« on: 23 Jun 2011, 12:46 am »
I just downloaded a hi res file from Bluecoast records.
It's Jane Selkye and Chris Kee    Slow Day.
I have it on my desktop as a wave sound file but when I try to transfer it to where I store my music I get a checksum error???
What am I doing wrong?? :scratch:
ted_b
Re: Help with first hi-res download...
« Reply #1 on: 23 Jun 2011, 12:51 am »
What is the sample rate/bit depth of this wav file, 24/96?  What do you mean "transfer it to where you store your music"?  Your hard drive?
rtate
« Reply #2 on: 23 Jun 2011, 10:57 am »
Hi Ted, the file is 24/96 and when I downloaded it I saved it to my desktop as a zip file.
I open it with winzip and then try to extract it to my external hd where my music is so that I can play it using foobar.
My system consists of a modded hiface transport feeding a Grant Fidelity Dac.
Aleg
« Reply #3 on: 23 Jun 2011, 11:20 am »
Sounds like the zip-file got corrupted while downloading.
Happens sometimes, in my experience esp when download speed is low.
Try redownloading it.
rtate
« Reply #4 on: 23 Jun 2011, 01:34 pm »
Thanks Aleg,  I will try again when I get home from work...
