Friends, countrymen and fellow AKSAphiles!
After almost a month of endless testing, soldering and loads of emails back and forth to Hugh, I finally managed to nail the hum 'ghost' in my GK-1R to the ground (literally) this morning.
It turned out that the problem had nothing whatsoever to do with the layout (which neither Hugh nor I thought it had, although we came to have our doubts as time went by and nothing we could come up with seemed to help) or the the wiring.
Nor was it to do with faulty components or the design of the GK-1R - or even an error that I had made in the assembly process.
Instead it turned out to be a combination of things (this is the way I see it), such as the slightly unorthodox earthing scheme of my whole system, combined with the 'collaboration' between the Analogue and the Relay pcbs of the GK-1R, my interconnects, and perhaps a few other things that I don't know about.
The hum problem was solved by running a wire from one of the output ground pins on the Analogue PCB to the output ground plane on the Relay PCB. For now, the 'output ground plane' equals the metal housing of one of the RCA plugs on the interconnects running to the power amps (this was the easiest place to put a croc clip
Obviously, I will try to implement this 'grounding link' in a more elegant manner. I will let you know how, but now I'll just sit back and listen to the lovely music that comes out of my system
Thanks to everyone who sent me emails with good (and sound) suggestions - and a special thanks to Hugh for his inordinate patience in answering a huge load of emails!
Happy Easter to all!
