error 09
0 Members and 1 Guest are viewing this topic. Read 4616 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: error 09
« Reply #20 on: 21 Jun 2011, 11:13 am »
Hi Marius
I noticed above that when you use the front panel buttons you push Play and it goes to the next song.  When you see the folder in the display push the right hand navigation button to select the complete folder then hit the Play button.
James
