0 Members and 1 Guest are viewing this topic. Read 9221 times.
I have two large windows in my room.Bamboo blinds make excellent diffusors.Thick heavy curtains in a second layer over top will help enormously with echo and glare.Controlling bass requires a different solution.Three tried and true methods are #1 multiple subs #2 DSP room correction #3 bass traps.
Or use OB subs. I've been in really difficult rooms, acoustically, and boxed bass was never able to perform at an acceptable level for me, even with the 3 options you mention. On the other hand, when I went to an OB speaker, the bass issues resolved themselves immediately.
+1Look up acoustical curtains (heavy, ugly, and barely effective as treatments).
Zitoun, I'd recommend that you start a new thread (still in the acoustics circle) in which you describe your room layout, current system, any existing acoustic treatments, speaker placement limitations, etc.. (ideally with a drawing) and then ask for recommendations. You're getting a lot of recommendations now, but without knowing additional details of your setup and constraints, it's hard to assess which are actually most applicable.
Zitoun, suggest matching speakers to the room. If room is small, speakers should be small. If room has limited potential (small, odd shaped, lots of reflective materials, lots of outside noises, limited availability (shared space), limited setup options (again due to being a shared space), be honest with yourself and consider a less expensive in-room system, or going with a headphone based system, or augment a less expensive system (possibly HT system if the TV is in the room) with a nicer headphone based system. By odd shaped I mean long/skinny (that'll sound like a tunnel), or cubic (which boosts inherent in-room bass peaks/dips).
The biggest mistake I see made in audio is overbuying gear for the available (limited potential) room. The second biggest mistake I see is buying trophies (lots of big glitzy boxes to show off - like thick sculptured faceplates or fancy veneers that add cost but not sound quality). Note that previous few of those you'd try to impress are truly interested in audio. Now-a-days the Cheap and Cheerful circle here at Audio Circle makes a ton of sense especially if you're going the digital route as value is extreme and the sound quality gap between cheap and expensive gear is shrinking.
To learn about audio recommend learning more about music. Attend live (unamplified) concerts to learn what "real" music sounds like. Discover what sonic attributes you seek (tight bass, pin-point imaging, life like dynamics, warm sound, etc.). Read Floyd Toole's "Sound Reproduction" 3rd edition to understand how speakers behave in-room. Peruse equipment reviews until you find individuals that you seem to jive with and then follow them. Then audition gear at friend's homes or at shops. Audition with a variety of the recordings you like and limit yourself to 3 or 4 auditions per day of stuff you might seriously consider buying to avoid hearing fatigue, and take notes which will force you to really listen.
