0 Members and 1 Guest are viewing this topic. Read 14042 times.
Here is another VTA adjuster I considered, but I don't think it is "on the fly" adjustable.http://www.cabezon.eu/product_info.php?products_id=120I would never adjust the tonearm on the fly anyway for fear of zinging it across the platter.This one also has the height starting pretty high because of the structure to mount your arm on it. More than the 4 MM total I use.My thinking is, starting too high creates problems with the VTA to begin with. It can't be low enough to start at level.I use the 2> 2 MM spacers and it is perfect now at 4MM. Both mechanisms look to be both over 4MM.What do you do then? You can't really or don't want to change the height of the platter?? I do have a tapped 3g spacer on my DL103R at the cartridge end.So I decided against both of these VTA adjusters for the 3 point mounting. 2" Stainless screws with nuts through the plinth works very nice for the sound.I like the way things sound now, but probably like the old simpler Rega post/ nut mounts better.As always, YMMV.Pete is a pretty stand up guy and I know he would let you return anything that didn't work out.Let me ask this. Wilson in your last pict is that the lowest setting you have on the arm mount? It will go down no further? That plate has to be tapped for the special length screws to tighten and not go through it so they would not stick out stopping it.D
I have never wedged a cartridge nor would I, to fix an upgrade.
I thought VTA on the fly was part of the appeal. I have that on other arms and it's no problem using it while the record is playing.
Roy Gandy does not even believe in VTA. You know that if you were in the business. The only reason he sells any shims at all is because of all the OEM arms out there and there are a lot of them.All the upgrades comes from this too because it is used on all different tables. All the upgrades can be purchased at reasonable cost and you can buy in increments.I bet Groovetracre's machining is better than Rega's.I'm not compulsive enough to change the VTA on all the different thickness of vinyl out there. So VTA on the fly is not for me.I have never wedged a cartridge nor would I, to fix an upgrade. If it works for Wilson that is great, he is fine with it.
Would one of these work? This is what I have on the DL103R.http://www.cabezon.eu/product_info.php?products_id=111
