Audio/Video Gear and Systems
The Apple Core
Crimson
Budget DAC Recomendations For Apple TV Server
Maceo23
18 Jun 2011, 01:33 pm »
I want to build a music server around my Apple TV without breaking the bank. I'd like to get a decent dac for it without having to spend $500 on it. Any recommendations would be very appreciated. I'm willing to go used to save some dough.
wilsynet
Re: Budget DAC Recomendations For Apple TV Server
18 Jun 2011, 07:53 pm »
Audio GD NFB-3 or NFB-2.
ssglx
Reply #2 on:
18 Jun 2011, 09:17 pm »
Easy, very easy. Musical Fidelity V-dac. It sounds wonderful. So much so that I just bought a 2nd ATV in case the first one shoots craps.
I couldn't bear to be without this little system.
bretth
Reply #3 on:
30 Jun 2011, 02:01 pm »
It's a bit of a bulky item next to the apple tv but there is no better value dac than the nfb-3. Having owned both, there's not much point in getting the nfb-2 unless you're using a more refined source than the apple-tv. Using a digital dock I was struggling to tell the difference.
pearsall001
AAD 2001 monitor
Reply #4 on:
30 Jun 2011, 03:26 pm »
Canbridge Audio DacMagic...paired up with my Sonos system it sounds incredible.
Russtafarian
Typical reaction to the music I play
Reply #5 on:
30 Jun 2011, 05:06 pm »
Michael Mercer wrote an article on this exact subject for the Daily Swarm last month.
http://www.thedailyswarm.com/swarm/sonic-satori-mini-system-grows-and-turning-your-appletv-music-server/
Russ
mr_slim
Reply #6 on:
17 Jul 2011, 11:34 pm »
Have a look at the new EMU 0204, if you are good with USB only connectivity. It uses the same DAC as the 0404, and sells for around $125 on Amazon. It will do 24/192 out via USB on OSX and Linux(USB 2.0 Audio compatible)
The Apple Core
Crimson
