iDac with Off-Ramp 4 - TAS review
0 Members and 1 Guest are viewing this topic. Read 23177 times.
audioengr
« on: 15 Jun 2011, 08:05 pm »
For those that don't subscribe to TAS, the review of the Peachtree iDAC in the July/August issue is very interesting.
http://www.avguide.com/review/peachtree-audio-idac-tas-214
Steven Stone concludes that the digital source is actually more important than the DAC itself.  When the iDAC and the W4S DAC's were driven with his Off-Ramp 4, not only did they each sound a lot better, they sounded almost identical.  No surprise to me :thumb:
This is all the more reason to invest in a really good digital source, with the best clock you can get.  Anyone know where to get one of those? :wink:
Steve N.
« Last Edit: 23 May 2013, 12:22 am by audioengr »
serengetiplains
Re: iDac with Off-Ramp 4 - TAS review
« Reply #1 on: 16 Jun 2011, 02:26 am »
Congratulations, Steve.  I think you're quite right about the importance of clocking.  It is, after all, the essential aspect of digital signal transfer fidelity.  What else does digital fidelity concern?
« Reply #2 on: 16 Jun 2011, 03:35 am »
Hi Steve,
At some point I was thinking about getting a miniDSP 4x8 since I actively tri-amp my speakers.  Do you think the off-ramp would be a good fit with something like that?
audioengr
« Reply #3 on: 16 Jun 2011, 04:52 am »
I put analog distortion from compression as #2.  Eliminating the preamp improves this.
Other principal digital things that affect fidelity are:
1) digital filtering  - use it sparingly or not at all
2) D/A conversion technique - affects resolution and S/N ratio - use modern D/A chips, but avoid switched-capacitor techniques
3) digital cable - make sure it's 1.5m long and low-loss
Steve N.
« Last Edit: 16 Jun 2011, 05:06 pm by audioengr »
audioengr
« Reply #4 on: 16 Jun 2011, 04:54 am »
Hi Steve,
The Off-Ramp provides a low-jitter digital source for any system.  What is a miniDSP?
If it's like a DEQX, then this will work well.  A number of my customers use the Off-Ramp to drive DEQX.
Steve N.
werd
« Reply #6 on: 16 Jun 2011, 04:10 pm »
Thats good news Steve. How about usb cables into the off ramp? Is it insensitve to change on the computer side of it ? If so you could possible have the first audio streamer thats also the starting gate in an audio chain.  :thumb: All you want to hear is differences in file resolution and thats it imo.
audioengr
« Reply #7 on: 16 Jun 2011, 05:01 pm »
I have not done this test since I updated the voltage regulators.  I previously had to use a Polestar with the Off-Ramp 3, but I have found that a 16-foot Belkin is fine with the Off-Ramp 4.  It probably does make a small difference however.  I had one report from a customer to this effect, but he did not have the latest voltage regs.
Steve N.
targa02
« Reply #8 on: 11 Oct 2011, 04:27 am »
Steve N.
Hi Steve,  With regards to the digital cable length - Should it be less than or equal to 1.5m long or is there something special about 1.5m in length?  Also, how does one determine if a cable is "low-loss"?
Thanks for your response!
audioengr
« Reply #9 on: 11 Oct 2011, 04:36 am »
1.5m is the minimum length.  I would try to keep it shorter than 3 meters.
Low-loss means low dielectric constant in the insulation, such as Teflon, expanded Teflon, or air.  Also, to mininize skin-effect, conductors should be 26 gauge or less.
Steve N.
audioengr
« Reply #10 on: 14 Nov 2011, 02:26 am »
Just for grins, I measured a new (no break-in) Off-Ramp 4 with Turboclock and USB Hynes reg and BNC output for P-P jitter.
It comes in around 170 psec for overall worst-case jitter on the S/PDIF output now.  This is a reduction of about half due to the USB Hynes reg.
Nice.  I think the Off-Ramp 5 should measure even a bit lower due to the additional Hynes regs that are designed into that one.
Steve N.
DaveBSC
« Reply #11 on: 14 Nov 2011, 07:45 pm »
Steve N.
Steve, any idea how this compares to some of the competition? And what is meant by "worst case"? 170 psec seems kind of high, IIRC the Northstar USB DAC measured somewhere around 170ps.
audioengr
« Reply #12 on: 15 Nov 2011, 12:57 am »
Take a look at JAs measurements in the Nov/Dec issue of Stereophile.  He reviews the Off-Ramp.
Its important to draw a distinction between RMS and P-P jitter
Steve N.
DaveBSC
« Reply #13 on: 15 Nov 2011, 10:39 am »
What I'm wondering is how Audiophilleo is managing to get 15ps p-p jitter for their devices. Are they not measuring their S/Pdif output?
audioengr
« Reply #14 on: 15 Nov 2011, 06:16 pm »
I dont believe it.  Even on the bench, just measuring the clock alone driven from the very best power supply, you will not get 15psec.
It is best to make the decision based on sound quality anyway, not measurements.  Even JA realizes this now.
Steve N.
DaveBSC
« Reply #15 on: 16 Nov 2011, 04:08 pm »
What do you make of this measurement, comparing the Audiophilleo1 to a specialized, ultra low jitter clock, and a Grimm Audio CC1 master clock? The AP1 is right in league with these devices, suggesting that Audiophilleo is not making up their jitter measurements. I'm not making claims about sound quality, indeed from what I've read from owners it seems like the OR4 is among the very best sounding converters out there. It's just that 170ps p-p jitter on the output (or 300+ without the USB regulator) just doesn't seem that impressive of a result.
Stereophile recently measured Simaudio's Moon Evo CD player for example at 69ps p-p on its output. Granted it costs $8K, but that includes dealer markup, and its also a CD player which adds more than a little to the cost of its internal digital circuitry.
jtwrace
    • TIPP YouTube Channel
« Reply #16 on: 16 Nov 2011, 04:14 pm »
This is a pretty interesting thread about jitter.
http://www.computeraudiophile.com/content/Timing-errorjitter-reduction
audioengr
« Reply #17 on: 16 Nov 2011, 06:33 pm »
The plot looks good, however the different signal levels is concerning.  Is this really apples to apples?
Are we comparing clocks to clocks or S/PDIF data to clocks?
BTW,  a customer in Australia who has Audiophillio just got his Off-Ramp 4 with Turboclock, no USB Hynes reg.  He says it beats the Audiophilleo.  He is sending it back for the USB Hynes upgrade too.
Steve N.
DaveBSC
« Reply #18 on: 16 Nov 2011, 08:29 pm »
I think this test was measuring the clock of the AP1 vs. the other two, rather than the usual S/Pdif output. AP's specification of 15ps p-p using their WaveCrest I think was done with S/Pdif. I've heard from a few people that using bus power seems to reduce the performance of the AP quite a bit, despite the "regenerative" internal power supply. I'm amazed that the $2900(!) Sonicweld Diverter HR continues to use bus power. They obviously go to herculean lengths to try to clean it up but, why bother with all that when you can just use either batteries or a nice linear supply? I don't get it.
Do you know of any comparisons of the OR vs. the Berkeley Alpha USB? These are the two I'm most interested in. Even if the Diverter solves all of the USB power issues, the price is so high that it's silly. If you're going to spend nearly $3,000 you might as well just skip the converter altogether and buy a USB DAC.
audioengr
« Reply #19 on: 16 Nov 2011, 11:01 pm »
That's what I suspected.  My clocks are just as good if not better.
I also have a NEL clock that I can put on my Turboclock which measures phase noise at -128dB at 10Hz.  When comparing this to my current clock from Crystek, the audible difference is small.  The Crystek is -155dB at 10kHz.
This may be at 10kHz.  At 10Hz, the plot puts the RMS jitter at about 500psec, and this is just the clock alone.
Me either.  Whats the point?  Make it simpler and then charge $3K??
BTW, I discovered that my new Hynes design actually outperforms LifePO batteries.  I put both in the OR4 and compared them.
Agreed.  I dont know anyone that has one yet, only the review in July/Aug TAS.  Pflaumers background is not really digital design according to the review.  Harley compares it driven by a Mac compared to a Lynx card in a PC, which is not interesting or particularly useful IMO.  It's really too bad that Steven Stone did not do this review. He would have put it head-to-head with my Off-Ramp 4.
Steve N.
