Digikey
0 Members and 1 Guest are viewing this topic. Read 1573 times.
robert123
Digikey
« on: 15 Jun 2011, 10:53 am »
Just getting my parts list together for my cornet 2, No luck with c100, c101 P11423CT-ND all out of stock or discontinued?
Substitute from an old post was 0.01uF AC = 495-1301. No stock
Another substitute from another post was P11423CT-ND guess what no stock.
Anyone got any more suggestions? would be really appreciated.
Rob
reuben
Re: Digikey
« Reply #1 on: 16 Jun 2011, 06:15 pm »
Mouser?
poty
Re: Digikey
« Reply #2 on: 16 Jun 2011, 07:03 pm »
Maybe
490-4254-ND
490-4244-ND
In the thread you have pointed to in your message was an explanation of the procedure (parameters) wich you can use to substitute the kind of parts.
mhconley
Re: Digikey
« Reply #3 on: 16 Jun 2011, 08:37 pm »
For hard to find parts try Octopart.  If Octopart can't find it it probably doesn't exist.  :)
Martin
robert123
Re: Digikey
« Reply #4 on: 16 Jun 2011, 11:50 pm »
Thanks for your help guys!
I just happen to locate some locally here in OZ, well they will be ordering from Singapore but i get to pick up in person which is a nice change.
if anyone is hunting for some here is the link
http://au.element14.com
They seem to have branches in a few locations.
Thanks again for you help
Rob
