IEC power jack and a removable 3 conductor power cord
0 Members and 1 Guest are viewing this topic. Read 33623 times.
srb
Re: IEC power jack and a removable 3 conductor power cord
« Reply #60 on: 23 Mar 2016, 11:34 pm »
Here is a plug, by its very nature and soulful purpose is to defeat the ground, and UL says that that's OK. They even gave it a listing number.
And of course it's purpose and use is not to defeat the ground when plugged into a grounded receptacle and circuit, but only to give the ability to use a grounded plug device in a home that only has 2-wire ungrounded receptacles and circuits.
jea48
« Reply #61 on: 24 Mar 2016, 03:22 am »
http://www.audioadvisor.com/prodinfo.asp?number=PSPWAC3
Yes, PS Audio says it is to be temporarily removed for testing purposes only.
But is the PC UL Listed?
JerryM
  • Where's The Bar?
« Reply #62 on: 24 Mar 2016, 03:33 am »
OMG.  :duh:
Are we second guessing Frank Van Alstine??
Really???  :guns:
 :duh:
jea48
« Reply #63 on: 24 Mar 2016, 03:43 am »
UL listed "cheater" plug:
I'm afraid some of you don't know who, which one your talkin' about........
It is not UL Listed to be used as a ground cheater. It is designed and manufactured as a 3 wire to 2 wire adapter.
No, it is not UL listed for the use of lifting the safety equipment ground from a piece of equipment or appliance. It was designed by the original manufacture as a device for connecting a piece of equipment or appliance that has a 3 wire cord and plug to a 2 wire receptacle that is fastened to a metallic outlet box, which is connected to a metallic conduit that is electrically continuous all the way to the grounded metal enclosure of the electrical panel it is connected to.
The metal tab on the 3 wire female/plug adapter is connected to the equipment ground contact of the female receptacle. The metal ground tab is designed to connect to the 6/32 threaded hub of the wall duplex receptacle by the 6/32 cover plate trim screw.
The 6/32 threaded hub is connected to the metal yoke, the receptacle supporting back strap, of the duplex receptacle.
Speedskater
  • Kevin
« Reply #64 on: 24 Mar 2016, 12:01 pm »
The correct (and safest) way to use a 3 wire plug & cord in an old 2 wire system, is to install a GFIC. Small form-factor GFIC's are now available to fit in the old smaller wall outlet boxes.
And no, a GFIC does not require a Safety Ground wire (EGC) to function correctly.
avahifi
    • http://www.avahifi.com
« Reply #65 on: 24 Mar 2016, 02:33 pm »
Our power transformers are double insulated so are safe with a two conductor polarized power cord (same as having ground lift switch open).
Frank
jea48
« Reply #66 on: 24 Mar 2016, 03:14 pm »
Frank
Interesting. Is your equipment UL Listed, or Listed by any other recognized third party safety testing laboratory, for use using a 2 wire power cord and plug?
Why do you give the user the option of using the safety equipment ground.
It's only purpose is to provide a low resistive path for ground fault current to travel back to the source in the event of a ground fault condition.
Jim
Speedskater
  • Kevin
« Reply #67 on: 24 Mar 2016, 03:33 pm »
Yes, a double-insulated component needs to be tested by a NRTL and bear the square in a square symbol. Otherwise if it's metal it requires a 3 wire cord.
