New BDA/P user
0 Members and 1 Guest are viewing this topic. Read 4750 times.
SHV
New BDA/P user
« on: 13 Jun 2011, 02:27 pm »
My BDA and BDP arrived last week; unfortunately I am in the middle of moving into a house that still is in the process of renovation/remodel.  Last night, I was able to do a quick set up with sp 1.7 and the BDs.  It is on my home network and works with flash drives.  At the moment, I don't have the time to educate myself on system set up.  (I know nothing about streaming or music servers, etc.)
Is the BDP compatible with the i-tunes library on my wife's Mac Book and i-phone?  If so, how do I get them to link up?
  • The Demo is Everything!
    • http://www.bryston.com
Re: New BDA/P user
« Reply #1 on: 13 Jun 2011, 03:09 pm »
Hi Steve,
With the BDP-1 you would have to copy your music library to a USB thumb-drive or 2.5 inch Hard-drive as a start point. Use a thumbdrive or harddrive which is fomated FAT32 or NTSF - which most are if not purchased at a MAC store.
Have you listened to the Bryston Thumb-drive that came with the unit - that will tell you if everything is working on the BDP-1.
On the BDA - just connect your wifes USB output to the USB input on the BDA-1.  Can your dealer help you out with this - is he near-by?
james
SHV
Re: New BDA/P user
« Reply #2 on: 13 Jun 2011, 07:47 pm »
"Can your dealer help you out with this - is he near-by?"
Nearest listed dealer is ~ 150 miles away.  Purchased my units from Audioadvisor.  No problem downloading from HDtracks and playing on system, also the 10 internet radio stations work fine.   Was interested to know if i-tunes library can be streamed to BDP.  Hopefully in a month or so, I can do some remedial self education on set-up, interface, etc.
Thanks for the response.
Re: New BDA/P user
« Reply #3 on: 13 Jun 2011, 07:53 pm »
Hi Steve
No the BDP is not a streamer - all music must be attached.
James
jas007
Re: New BDA/P user
« Reply #4 on: 13 Jun 2011, 10:38 pm »
Of course, one could always stream music from Itunes to an Airport Express connected to the BDA-1 via an optical cable.  I've done that along with buying a BDP-1.  Sounds OK.
In any event, if your I-tunes library isn't too big, just buy a small portable hard drive and copy all your music to it, and then plug that into the BDP-1.
SHV
Re: New BDA/P user
« Reply #5 on: 19 Jun 2011, 03:56 am »
I have been using my BDP-1 with flash drives and internet radio without problems...the more I use this digital gadget, the more I like it.  Tonight I showed the wife how to access BDP-1 local and she loves it.  (Hasn't asked "Are those things with the green lights new?"...yet...)
I connected her I-Pod nano with about 2k songs, this PM.  I-POD says it is connected and the double arrows are spinning...BDP-1 shows BDP-1 and' loading" but nothing shows up on my "Home" other than Playlist and when I click that then Radio1.  No change after about an hour of being connected.
Suggestions????
saveloy
Re: New BDA/P user
« Reply #6 on: 19 Jun 2011, 10:39 am »
Steve,
I may be wrong, but as far as I understand it an iPod cannot be used with the BDP-1.
You can, however, plug it into the BDA-1 via its rear USB B socket.
Kyri
Re: New BDA/P user
« Reply #7 on: 19 Jun 2011, 11:36 am »
Suggestions????
Hi Steve,
The BDP-1 has to see a 'drive' and it does not with the iPOD - we are looking at that and may be abble to do something in the future.
james
SHV
Re: New BDA/P user
« Reply #8 on: 19 Jun 2011, 02:35 pm »
Thanks for the help...Can I down load the I-tunes library to a fat-32 formatted HD?  If so how?  As you can tell, I am still stuck in analog point A to point B wiring mentality and abilities.
Re: New BDA/P user
« Reply #9 on: 19 Jun 2011, 04:41 pm »
Yes but album art may be an issue if that's important to you.
Just connected the FAT 32 formatted thumbdrive (most come that way unless its a MAC store) and transfer the files from the computer to the thumbdrive using Finder I believe?. (I am not a MAC guy)
james
SHV
Re: New BDA/P user
« Reply #10 on: 23 Jun 2011, 03:06 pm »
Will the next software release allow me to connect a Mac formatted 6 TB OWC raid to the BDP and have functionality with MAX?
Re: New BDA/P user
« Reply #11 on: 23 Jun 2011, 05:21 pm »
Hi Steve - I do not think so - but I will check.  The BDP-1 was never really aimed at customers wanting access-ability of centralized huge libraries.
james
SHV
Re: New BDA/P user
« Reply #12 on: 23 Jun 2011, 05:45 pm »
Thanks for the reply....Just thinking "out loud" about possibilities of ripping part/all of my cd collection and how to integrate that into my evolving play-back options including the BDA/P.  More than likely, I will repeat the same road as video, repurchase hi-rez versions if/when they become available.
SHV
Re: New BDA/P user
« Reply #13 on: 5 Jul 2011, 04:14 pm »
Can the BDA be used to "feed" two pre-amps via the single-ended and balanced puts?  I want to set up a out-door speaker system and Ihave a Parasound pre-amp with balanced inputs that is sitting in the closet.
The Parasound and an inexpensive amp be more than satisfactory for a pool-side sound system if I can use the BDA as a source.
Re: New BDA/P user
« Reply #14 on: 5 Jul 2011, 04:16 pm »
Hi Steve - yes you can use both outputs at the same time.
james
SHV
Re: New BDA/P user
« Reply #15 on: 5 Jul 2011, 04:40 pm »
Thanks for the help. (Yikes, I just re-read my terrible typing, thankfully you could decrypt the message. :>)
