Vandy 1b on my local CL
0 Members and 1 Guest are viewing this topic. Read 2776 times.
rahimlee54
« on: 11 Jun 2011, 12:09 am »
There are a pair of Vandy 1b on my local CL that I am thinking about buying,  guy giving them for 175, should I jump on these.  I dont exactly have a place for em but for the price I might be able to work out something.  Opinions?
Jared
neobop
  • BIRD LIVES
Re: Vandy 1b on my local CL
« Reply #1 on: 11 Jun 2011, 01:14 am »
Hi, I guess it would depend on what you have. Those are some really nice speaks. I had a pr of 2C back in the '80s and they were a little big for my room. The 1B would have been perfect. I actually liked the 1b more. It's a classic 2-way 8" that sounds like music. Has decent bass extension and will play fairly loud, within reason. If they check out, I'd give it serious consideration for 175.
neo
rahimlee54
« Reply #2 on: 11 Jun 2011, 01:25 am »
I have a pair of salk HT2-TLs for dedicated 2 channel but I think those would be a really good second system.  How much room do they need to breathe?
neobop
  • BIRD LIVES
« Reply #3 on: 11 Jun 2011, 08:47 am »
I guess that would depend on the room. They have a tiny footprint, maybe 1 ft sq. They are prob best, out from the back wall at least a couple of feet. City dwellers use them in some very small rooms. I used to demo them in a rather large room, maybe 18 x 30.
Don't underestimate the quality of a Vandersteen. These are time aligned and minimum phase. Vifa custom makes drivers for him and they were far and away my favorite speaker anywhere near that price range. They might not be showy or super impressive like some wild looking piece of sculpture but they are coherent and can really sound nice.
If you're not familiar with the company, expect something warmer than a Dynaudio and with probably less SPL capability and transient response performance. On the other hand they would blow away a small pr of Maggies or similar. Other 2-way 8" weren't much competition either. Companies like Snell, Thiel, B&W etc were 10 times the money and never equalled the coherence and natural sound of the 1b. They're for listening to music, not looking at a hype sheet. They're in Calif and I would imagine would support if you need a part or whatever. These might be pretty old so you should check them out. Id guess that you'd have to spend 5X that on a new pr, to find something worthy of comparison.
neo
