Frequency Range
0 Members and 1 Guest are viewing this topic. Read 5572 times.
Richard in Idaho
Frequency Range
« on: 10 Jun 2011, 02:17 am »
What is the frequency range of the following?
Type 1
Type 3
Type 4
Hank Murrow
Re: Frequency Range
« Reply #1 on: 16 Jun 2011, 01:08 am »
Richard; I queried Louis about this question and here is the Summary:
The frequency response for the Type 1 is 60 to 18KHz sealed; and 48 to 18KHz vented.
The frequency response for the Type 2 is 50Hz to 18KHz  sealed; and 38Hz to 18KHz vented.
The frequency response for the Type 3 sub is 27Hz to 150 variable and sealed only.
The frequency response for the Type 4 with the sub built-in is 27-18KHz. Louis would keep the upper section of the type 4 sealed.
I hope this helps you determine which model fits your room/system.
Cheers, Hank, Super 5 owner.
Richard in Idaho
Re: Frequency Range
« Reply #2 on: 16 Jun 2011, 01:35 am »
Thanks, that is just what I wanted.
What I like about the Type 1/3 over the Type four is that I would not need to get both at the same time.
Hank Murrow
Re: Frequency Range
« Reply #3 on: 16 Jun 2011, 02:59 pm »
And what I like about getting a pair of 4's is that the trade-in for my Super 5's is larger. YMMV!
Cheers, Hank
Louis O
Re: Frequency Range
« Reply #4 on: 18 Jun 2011, 10:07 pm »
Hi Hank and Richard,
Great posts. The 1/3 combo is modular so you can get them in time which is a great way to go.
That's right Hank thanks and looking forward to making a set for you.
There a lot of fun.
Thanks again,
Louis
