bdp-1 not appearing on network
0 Members and 1 Guest are viewing this topic. Read 10957 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: bdp-1 not appearing on network
« Reply #20 on: 23 Jun 2011, 11:46 am »
yes me too...thanks.
afraid to push the on/off button though..
funny thing is that via a rather large detour, I'm back again to my original problem: the BDP1 not playing the Chandos USB sticks in the right order.....(see above, where the Mac finder does show it right). I believe to be rather certain now that when and where the original recording consisted of more than 1 cd, they are put into 1 folder in the Chandos USB. BDP1 plays them ordered numerical but doesn't see the separate cd's, and thus mixes them up altogether. Cd1 track 1, cd2 track 1, cd1 track2, cd2 track 2 ec etc. Most other machines and software programs read them in the correct order, as seen above.
I can make a correct playlist in the Max softwareinterface, but do not believe that would have to be done. In fact it feels rather clumsy and un-userfriendly. I just want to load a usb-stick, or folder on a HDD for that matter, and hit play. Just like in the old days with old fashion cd's....As Bryston says: we have to see the BDP1 as a modern-age  cd player. Well, it should act as one!  :wink:
Marius (downloading gigabytes of music right now... :P)
ps James, how do I delete a single track out of a playlist again? You must have mentioned it somewhere, but I can't find it anymore. Keep having to delete the whole playlist....and start over again
In Max?
James
Marius
« Reply #21 on: 23 Jun 2011, 11:54 am »
« Reply #22 on: 23 Jun 2011, 12:01 pm »
Click on Current in the left hand colum and then hit the little white square on the songs you want deleted - then on the bottom hit Remove Selected.
Then hit Save Playlist  :thumb:
James
Marius
« Reply #23 on: 23 Jun 2011, 01:26 pm »
aha, thanks, missed that before.
Marius
James
skunark
« Reply #24 on: 23 Jun 2011, 11:12 pm »
Guessing your Airport Express is configured as a router?   If you switched it to an 'access port' it should work fine.   If your Airport Express is configured as a router it would block certain protocols by default keeping it's local network secure of the other network.
Marius
« Reply #25 on: 24 Jun 2011, 09:05 am »
i believe to have it configured as a "bridge". it extends my wired network and is not used as a router.
Marius
