For Sale: "SOLD" Von Schweikert VR-4 JR Mk3 and LCR-4
0 Members and 1 Guest are viewing this topic. Read 6740 times.
DKane
Members - I've got something pretty rare here that you might be interested in.  A beautiful pair of the VSA VR-4 JR Mk3's in African Hazelwood, and an LCR-4 in Piano Black.  I'm the original owner.  I purchased these directly from Mr. Von Schweikert himself, as I had the good fortune to be a beta tester for the Mk 3's at the beginning of their production in July of 2009.  I acquired the LCR-4 in exactly the same way, directly from the California factory, in February of 2010.
All three speakers are in exceptionally fine shape. They've been in a pet, child, and smoke free environment from day 1.  On an Audiogon scale I'd rate them all as a 9, but in truth they're better than that.  Price for the VR-4's is $4,500.00.  Price for the LCR-4 is $1,250.  I'd prefer to sell them as a set, so for anyone interested in all three I'm prepared to make a deal.  Having said that, please be aware - these are very heavy, so shipping will not be cheap.  The VR-4's are 100 lbs each - crated you're looking at approx 260-270 lbs for the pair.  The LCR-4 is about 50 lbs - closer to 60 lbs when boxed up.  My zip code is 32566 (Navarre, FL).
I've got all the original paperwork, crates, everything.  And I can send you all the pictures you'd like to have.  The serial numbers for the VR-4's:  0958R, 0958L, and for the LCR-4:  014030.
Thanks for your interest.  Feel free to ask anything you'd like to know.
« Last Edit: 28 Nov 2011, 01:41 pm by DKane »
scb
Re: For Sale: Von Schweikert VR-4 JR Mk3 and LCR-4
« Reply #1 on: 7 Jun 2011, 05:40 pm »
what are the dimensions of the lcr-4?  any link to specs?
DKane
« Reply #2 on: 7 Jun 2011, 07:05 pm »
Here's the info from a Press Release regarding the LCR-4:
Designed for use with the VR-33, VR-4, and VR-5 Series of speaker models, the new LCR-4 is a giant step forward in the area of vocal intelligibility at a reasonable price point.  This new center speaker uses very high quality drivers designed by Scanspeak of Denmark, the company who supplies Wilson, Magico, YG Acoustics, and other top quality manufacturers who use these drivers in systems costing up to $150,000/pr.
Since the twin 178mm (7”) bass-mids have to reproduce both the bass and midrange frequencies, it is a challenge to design a driver that will reproduce the human voice with extreme clarity, while also being asked to reproduce deep bass frequencies at a high volume level.  In order to obtain the maximum vocal intelligibility, the LCR-4 uses specially designed drivers that were optimized for this function, and consist of high-tech laminated cones driven by patented Low Distortion Motors.  The Revelator 1” tweeter has a long throw design, chambered rear cavity to reduce resonance, specially treated fabric dome, and the Low Distortion Motor.   This tweeter combines both high detail with extremely smooth sound, especially in the important vocal range.
LCR-4 SPECIFICATIONS
Frequency Response – 32Hz to 25kHz (+/- 3dB)
Impedance – 4 ohms nominal
Power Rating – 50 watts to 200 watts r.m.s.
Sensitivity – 90dB @ 1watt 1/meter
Size – 9.5” tall x 22” wide x 14” deep
Weight: -  51 lbs raw, 60 lbs packed for shipping
Construction -  Triple-Layer laminated sandwich of resin impregnated MDF, artificial stone, and rubberized felt, 75mm total thickness, with honeycomb internal bracing.  This hi-tech wall eliminates the colorations found in competing systems and is one of our “secret weapons” in the vocal clarity of this model.  Bass loading is an infinite baffle, sealed box for maximum vocal clarity.
Bass/Mids – 2 pcs Scanspeak treated-paper units, 7” dia, with 38mm high power voice coils, Low Distortion Motors, cast frames, copper clad pole piece, and long throw suspensions.  This is the same driver used in speakers at $15,000/pr.
Tweeter – 1 pc Scanspeak silk dome Illuminator tweeter, Low Distortion Motor, rear chamber cup, cast metal frame, and Ferrofluid liquid cooling for high-temperature protection.  This tweeter is used in speakers costing $34,000/pr.
Input – One pair of WBT satin finish Rhodium plated five way binding posts/
Crossover – Fourth Order Global Axis Integration Network using premium film/foil caps, air core inductors, and metal film resistors,
Warranty – Ten Years, parts and labor (excluding abuse such as amplifier clipping).
scb
« Reply #3 on: 7 Jun 2011, 08:12 pm »
damn, 9.5 high might be too tall for my room.  looks like the perfect center for the unifield 3, though...
kudoosamod
Re: For Sale: "SOLD" Von Schweikert VR-4 JR Mk3 and LCR-4
« Reply #4 on: 17 Dec 2011, 08:41 am »
are they still for sale ?
