Recommendations on a high quality digital media transport
0 Members and 1 Guest are viewing this topic. Read 3000 times.
Kwebb
Any recommendations for a high quality digital media transport to be used with the AVA DAC would be greatly appreciated.
srb
Re: Recommendations on a high quality digital media transport
« Reply #1 on: 3 Jun 2011, 03:40 pm »
1.  Bryston BDP-1 Digital Player
2.  Apple Mac Mini using iTunes + Pure Music software player
The BDP-1 has a coaxial S/PDIF output.
If the AVA DAC has an optical input you can use the optical out of the Mac Mini for up to 24/96 or use a high quality external USB to S/PDIF converter (a) if it doesn't have an optical input, (b) for up to 24/192 or (c) for the best sounding interface.
« Last Edit: 3 Jun 2011, 05:27 pm by srb »
Wayner
« Reply #2 on: 3 Jun 2011, 06:07 pm »
The Vision EC DAC has 4 inputs, 2 toslink, 2 S/PDIF.
I believe an Oppo has a nice performance to price ratio.
http://www.oppodigital.com/blu-ray-bdp-93/blu-ray-BDP-93-Features.aspx
Wayner
srb
« Reply #3 on: 3 Jun 2011, 06:12 pm »
I though "digital media transport" was referring to a digital file player, but Kwebb might have in fact been simply referring to a universal disc player.
Charles Calkins
« Reply #4 on: 3 Jun 2011, 06:22 pm »
Wayner
  Wayner
 I got much,much better audio results hooking a DAC by SPDIF cable to a dedicated CD player rather than a BluRay or a DVD/CD player. I tried several DVD/CD players including Oppo. Something about a whole lot of "Jitter" in a DVD/CD player whereas a dedicated CD player has less "Jitter"
                                            Cheers
                                            Charlie
Wayner
« Reply #5 on: 3 Jun 2011, 09:00 pm »
The OP is looking for a "media" transport, so that is not a CD player.
 8)
floresjc
« Reply #6 on: 3 Jun 2011, 10:02 pm »
I use an Airport Express and Squeezebox Duet that are much to my liking. If you are an Apple-head, Airport Express with AirTunes is the way to go. If you have loads of FLAC files, Squeezebox will work marvelously.
