Suggestions needed: Upgrade from Blue Point Special
0 Members and 1 Guest are viewing this topic. Read 3749 times.
Scott F.
Re: Suggestions needed: Upgrade from Blue Point Special
« Reply #20 on: 31 May 2011, 12:57 pm »
Glad to hear that the Dyna is working well. It didn't dawn on me to double check compliance before commiting to the cart.  :duh: hopefully it's pretty close and doesn't cause any issues.
Be sure to play with your VTA. It can make subtle but distinct differences in sound.
That Tull you are looking for could be a tough one to find. That may be an eBay item.
Enjoy the cart and be sure to give Peter a call at Soundsmith about your Bluepoint. He'll know immediately if it's worth retipping or you should just start looking for another cart.
neobop
  • BIRD LIVES
« Reply #21 on: 9 Jun 2011, 08:56 pm »
I have to wonder how a company can retail a cartridge for less than it's dealer cost.  Makes me awfully suspicious.     :o
It's called grey market. They bypass the US distributor and import it themselves. It's my understanding that they back it up too. No valid warranty is usually the risk you take buying grey.
neo
