0 Members and 1 Guest are viewing this topic. Read 16025 times.
Since it appears that battery kits are on hold temporarily I will go ahead and try the linear supply as my first upgrade. It's fine, I want both a nice ps and also batteries so I can have both flavors to choose from.But when I get it, will it connect directly to my Two.2? Or will I need some kind of adapter?
Just find yourself an Astron and get a cord made, Jason can probably help you there. The cable will have ring terminals that screw onto the back of the Astron.
Is it ok to dial it up to 32 volts? Two.2 can handle that right?
I can only imagine. The shipping weight is over 18 pounds. I don't think the stock supply weighs even 1.Is it ok to dial it up to 32 volts? Two.2 can handle that right?
Let me understand something. So if I were to buy a second Astron and a second Two.2 for biamping that would not actually give me 87 watts let side? I would still only be 55 watts per side, is that right?Because I was under the impression from the manual that if Imonoblocked i would get full power to each channel. I was kind of hoping.
