0 Members and 1 Guest are viewing this topic. Read 16543 times.
Greetings,To cut a long story short. First trip to a 'mid-fi' store blew my mind when I auditioned some Sonus Faber driven by a stack of McIntosh equipment. I've listened to live concert for years but never thought reproduced music could sound like that . (Apologies - as I said, I'm a newbie.) Preferred that sound over the B&Ws and Martin Logans. The fullness, weight, presence, warmth, musicality etc. So I'm looking to approximate as much of that as possible on a smaller budget, and smaller space. Namely, I'd like to put together a system for my office with listening distance of between 3 1/2 and 5 feet. Not a lot of distance from the speakers. What I'd like: 1. Tube amp for the warmth. 2. Speakers that produce a sense of weight, presence, and warmth even at low listening level for long non-fatiguing listen, but without being overly tubby and to retain as much detail as possible. Also, I'd like to have as much pinpoint imaging rather than just a wall of sound. 3. My music - acoustic classical, vocals, jazz, and the like. No rock, metal etc. Questions for you pros: 1. Would a full range single speaker be the best solution. Due to the close listening distance, I'm assuming that multiple drivers won't come together to at such a close distance. 2. I see many 'full range' speakers with a tweeter. I'm not understanding that - doesn't that make them function like a regular two driver speaker? Or does such a set up still image well? 3. Since I'd like a sense of weight and depth at low volume, I'm told that a larger driver is ideal. Yet at close distances, a smaller driver is supposed to give better imaging and staging. So how do I figure this out? What size driver may be ideal? 4. Any speaker recommendations? Thanks in advance for any help. UL
Greetings,To cut a long story short. First trip to a 'mid-fi' store blew my mind when I auditioned some Sonus Faber driven by a stack of McIntosh equipment. I've listened to live concert for years but never thought reproduced music could sound equally pleasurable. (Apologies - as I said, I'm a newbie.) Preferred that sound over the B&Ws and Martin Logans. The fullness, weight, presence, warmth, musicality etc. So I'm looking to approximate as much of that as possible on a smaller budget, and smaller space. Namely, I'd like to put together a system for my office with listening distance of between 3 1/2 and 5 feet. Not a lot of distance from the speakers. What I'd like: 1. Tube amp for the warmth. 2. Speakers that produce a sense of weight, presence, and warmth even at low listening level for long non-fatiguing listen, but without being overly tubby and to retain as much detail as possible. Also, I'd like to have as much pinpoint imaging rather than just a wall of sound. 3. My music - acoustic classical, vocals, jazz, and the like. No rock, metal etc. Questions for you pros: 1. Would a full range single speaker be the best solution. Due to the close listening distance, I'm assuming that multiple drivers won't come together to at such a close distance. 2. I see many 'full range' speakers with a tweeter. I'm not understanding that - doesn't that make them function like a regular two driver speaker? Or does such a set up still image well? 3. Since I'd like a sense of weight and depth at low volume, I'm told that a larger driver is ideal. Yet at close distances, a smaller driver is supposed to give better imaging and staging. So how do I figure this out? What size driver may be ideal? 4. Any speaker recommendations? My room is about 11.5 by 13 by 8 ceiling. Thanks in advance for any help. UL
You say you have a small budget and are looking for a single driver small speaker. You should check out the Fujitsu Eclipse range of speakers, you can not go wrong they are amazing.My friend uses the top of the range Eclipse TD712z Mk 2, you have to hear them to believe. I have also heard the small Eclipse TD508II wow they will blow you mind at what they can do for their size. If you can have a demo try them, I think your search will end there.Review of the TD712z here http://www.stereophile.com/content/fujitsu-ten-eclipse-td712z-loudspeaker
Those things are $7000/pair. They should sound good.
You say you have a small budget ... check out the Fujitsu Eclipse range of speakers
I have no doubt the the F10 are pretty special, they are doing some bleeding edge stuff, but small budget & F10 in the same sentence?dave
1. Presence. I'm told that even at the same decibel & frequency response, a 8" driver produces a different effect from a 4.5" driver.
2. I can pair the speakers with a single sub if necessary for bass. My sub can cross over up to 80hz.
single driver need as much distance as conventional multi-driver system to resolve. (Not sure if I'm using the right term.)
Fujitsu Ten’s Eclipse TD307II at £296 is not going to send you to the bank for a loan is it? I don’t think so.
Not a bad price (inclusive of VAT?), but a 2 1/2" driver with an F10 of 100 Hz likely is not going to meet the desired midbass presence.dave
