Cables
0 Members and 1 Guest are viewing this topic. Read 4546 times.
azhtnut
Re: Cables
« Reply #20 on: 18 May 2011, 03:36 pm »
Thanks Jack, good advice that I'll put to use.  The SVS subs sit on top of (2) Auralex sub dudes and the LCR-15 and stand sits on top of another.  The vibrations from those have been reduced a great deal from the sub dudes.  The LCR-15 clarity for dialog has really benefit from this.
However, there is another important reason to lower the stage from the 9" down to say 2 or 3" above the floor.   The main audio listening seat is directly on the floor, which puts the MKIIIs 10" higher with spike bars than that the listening position.  It does not matter on some material, but there is clearly alot of material that goes over my head literally with that difference.  I've added a couple of cushions to the seat and slouch a little less in the seat.  :wink:  The improvement in detail and clarity come from the MKIIIs has been dramatic with that small change.
So, vertical seating position (especially in multi-level home theater rooms like mine) is as important as the horizontal location most people are concerned with.
Marty
Current room - sorry for the washed out image - haven't figure out how to take pic of PJ screen with flash.
scb
Re: Cables
« Reply #21 on: 19 May 2011, 10:43 pm »
just finished hooking up my new speaker cables.  i replaced an older Audio Magic Sorcerer (silver) set with the newer Audio Magic Sorcerer Liquid Air (liquid polymer).  we'll see how it goes
I already love how flexible these are compared to the old Sorcerers, which were so stiff you could barely bend them and had spade connectors on them so large you could use them out in the garden.  these new cables have bananas and are very flexible (and thinner)
