I think a stock decware may not be as good az the tbi. My set was better but it uses much higher end parts vs the decware... and even then it was uncomfortably close. I also appreciated the extra power the tbi has.
I am getting an offer to buy this used: http://www.musicalparadise.ca/store/index.php?route=product/product&product_id=50Looks like a solid SET amplifier which should be a good match to my RS5 drivers. Thoughts?
...Now to the point. A couple of weeks ago I decided to buy a Pass Labs First Watt J2. This is a single ended 25 watt pure class A j-fet amp made by Nelson Pass. I was enamored by the write-ups online, especially on 6Moons so I decided I would buy it and then sell whichever of my amps was the lesser. Sound familiar?OMG. This is most certainly my dream amp. It seems to combine the best of solid state and tube-like attributes. It has remarkable detail, beautiful tone, and is in no way fatiguing. It seems to mate perfectly with the single driver crossover-less Omegas. The highest compliment that I can make is that I now just want to listen to music rather than fussing over the equipment or planning the next purchase. The Omegas disappear and then you just have music…I highly recommend the First Watt J2 with the Omegas.
I have experience with this amp with Axiom M22V3's and Beyer T1 phones. Excellent build quality and performance. If you can get for less than $300 I wouldn't hesitate one nano second.
Hi Paul, can you tell me what preamp you're using with the J2?Thanks!
I am using a Wyred for Sound DAC2 DSD SE. This is their Saber based DAC that supports DSD. It has a remote volume control and a fairly high output so works well as a pre. It also makes for a simple setup with a lot of convenience. I wish that it had a tad less gain so that I could keep the volume setting just a bit higher in what others have described as it's sweet spot. Having said this however it sounds great and my wish is just normal audiophiliac obsessiveness...At some point I would really like to hear a First Watt SIT2 as I am a big fan of SET tube magic...
Can't go wrong with these:
J2 and M2 are very different from each other. Both great amps and highly resolving, but their "flavors" are almost opposites in the Pass house sound. The J2 was designed for single driver speakers, and something to note is that Stereophile found the J2 to be less happy with speakers that are 4 ohm nominal (which the High Output Omegas are). Yes, I've owned both and preferred the J2. I'm still fond of it, though I no longer have it. I'd recommend it to anyone with standard, single driver, Omegas. High Output Omegas or other less efficient speakers would likely be more of a YMMV thing, depending on listening habits, room size, etc etc.I've owned the Aleph 30, M2, J2, F5, XA30.5, XA30.8, INT-150, and currently the F7. Yes, I'm hooked on Pass amps and Mark at Reno HiFi makes the process of buying /trying/trading very easy and fun. Great guy too!
Wow, RDavidson, that's an amazing set of amplifiers that have passed through your house. If I may request, would you put together some comments/comparison on this sequence of Pass/First Watt amps? I imagine it would take a separate thread so as not to hijack this one. I'm sure there are many on AC that would like to know your thoughts on these amps, pros and cons. You are in a unique position to have demoed all of these in your home rig, so we would really appreciate your assessment. In particular, I am curious about your thoughts on the XA30.5 vs. the XA30.8.Thanks, -dB
