0 Members and 1 Guest are viewing this topic. Read 57731 times.
Hi Bob, would you mind running me through your set up, i.e. crossover points and driver types and what they are doing frequency wise. Is the ripole to cover just very low down and what does it sound like at the upper end of its use. I am planning a three way set up with a tractrix horn from 1500Hz up, an Audax PR170MO preferably from 150-200Hz up to 1500Hz and some kind of encloure with a 15" woofer, would a ripole work for me?
You should consult with somebody about that 150Hz x-over for the Audax. It seems too close to it's resonant freq for comfort. Madisound sells the driver. You can call them for advise.Sorry to go off topic. Those 18" cabinets are beautiful. neo
They've got an accordion suspension in the center front of the cone as opposed to the normal convex dustcap. Someone else may be able to tell you what the (solid as a rock) plate in the center of the cone is.
That cap would be a cool guard for my shower drain, or maybe a belt buckle.
