Need help with remote control of Ipad2
Marbles
« on: 5 May 2011, 01:16 pm »
I'm using my Ipad2 to play music through Itunes in a stereo system.
I want to use my iphone4 as a remote control.  Anyway to do this?
If so, how.
Marbles
Re: Need help with remote control of Ipad2
« Reply #1 on: 5 May 2011, 09:40 pm »
Bump for help
ted_b
« Reply #2 on: 5 May 2011, 11:42 pm »
Rob,
Do you mean to say iTunes (or as an iPod, i.e local music to your iPad)?  The iTunes music database is not an iPad app, it sits on a laptop or Mini.  If you are using your iPad to access an iTunes database then you are using the Apple remote app...something that can also be done on an ipod or ipod touch, yes.  However, if you are using your iPad as a large iPod (i.e the ipod app) then no, it is local music on your ipad and not remote controllable via an iTouch or ipod unless you wanna try a screen sharing VNC app I guess, although I'm not sure the ipad screen can be seen via the network like a laptop or server screen.
So first please explain your use of "iTunes".
