ONE.2 low frequency jumper
0 Members and 1 Guest are viewing this topic. Read 1535 times.
badberry
« on: 1 May 2011, 09:50 am »
When I move jumper from default setting to cut low freguencies positions, would it also affect sub woofer out in any way ?
eclein
Re: ONE.2 low frequency jumper
« Reply #1 on: 1 May 2011, 10:37 am »
Nope....you'll still have the sub out feature.
PSB Guy
« Reply #2 on: 1 May 2011, 05:10 pm »
Ed is right, the jumper only effects the speaker outputs, the subwoofer output on the amp runs full range all the time. But, if you do change the jumper setting, you're going to have to change the crossover setting on your subwoofer to somewhere around 80 Hz, since the mains will no longer get any frequencies below that from the amp.
Cornelis
badberry
« Reply #3 on: 2 May 2011, 01:30 am »
Thanks for confirmation.
