0 Members and 1 Guest are viewing this topic. Read 6104 times.
Hey welome!!- The amps are dead quiet, break out the 30/130 and run that in too, hook it up like your dreaming about and sit back and enjoy, no need to plan run in--order pizza, change CD, order chinese, change CD, order cheesesteak, change CD, sleep a couple hours, Change CD, continue.....Thats all the direction you need here my friend...plug it all in and crank it up, do have any type of pre-amp around?? I turned my TWO.2 30/130 w/Auri's into an amp only with the jumpers and the 30/130 and making it an amp only were the best things I did. There are a few Piano M1 CD players I'm seeing used--I don't know why as they are out of stock for awhile and I think Seth may be close to exhausting his remaining inventory, a Virtue amp and Piano and like PBJ.........enjoy Ed
RealTraps is an excellent source for info/ articles re: room treatments, speaker placement, listening position, room nodes, etc..This link is for the "old school" frequency sweep method (SPL meter, listening to individual tones, recording results & experimenting w/ speaker placement/ treatments, then re-test):http://www.realtraps.com/test-cd.htmIt really helps w/ understanding your room's net effect to the "sound" you hear or don't hear (peaks, nulls, boominess, etc.).It also references more detailed software options, but I'm personally not there yet.It takes a lot of research & effort to learn, but it will help optimize your new equipment to full advantage.
