0 Members and 1 Guest are viewing this topic. Read 4598 times.
So if one had a choice cost no object it would be discrete design not op amp ? For the Manf. of say a DAC would the cost differential be worth the effort ? For the DIY crowd ?
There are ways to make an opamp run higher Class A/B output stage operation. You need to add a current sink at the output to force the bias up. There are a few companies that have done this over the years to make an opamp sound better. Adding a heatsink to the opamp will help with heat dissipation.
Why ? Are Op amps really a better solution ? Is cost or space the reason or are they better sonically than circuitry ? charles
