How do I reboot iPad 2 ?
abbee
« on: 21 Apr 2011, 07:28 am »
I might need to reboot my iPad 2 Verizen, because of the recent problems that some have had when they turn the cell off. I want to turn it on tonight to check. I read, but forgot how to reboot, since I have never done it. How do I reboot? Is it holding down both the power and home button at the same time?
Levi
Re: How do I reboot iPad 2 ?
« Reply #1 on: 21 Apr 2011, 02:08 pm »
Hold the switch on the top right of your iPad until you see "--> slide to power off"
santacore
« Reply #2 on: 21 Apr 2011, 03:37 pm »
Yes, that should do it.
