Sub-filter on Bryston BP-1.5 riaa?
0 Members and 1 Guest are viewing this topic. Read 7043 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Sub-filter on Bryston BP-1.5 riaa?
« Reply #20 on: 30 Apr 2011, 03:46 pm »
I'm digressing a bit but I seem to recall James saying that the mm/mc phono stage in a BP26 is the same as a BP1.5. That being the case, is there similar internal adjustability with a BP26 for gain etc. as with the stand alone phono stage?
Furthermore, I hava a somewhat rare and oddball Rega Apheta cartridge on my P9 - are the factory settings for the Bryston phono stage appropriate? I'm having trouble deciphering this stuff: http://www.rega.co.uk/downloads/Apheta%20Manual.pdf and http://www.rega.co.uk/downloads/Ios%20manual%20.pdf  and reconciling it with the BP1.5/BP26mm/mc manuals.
In short, are the Bryston factory settings such as they are on my BP26 mm/mc fairly optimal for my Rega Apheta's needs?
Thanks James, when you've got a chance.
Hi,
Yes the BP26 phono stage is identical so it can be configured as you wish.  It looks like the Rega Cartridge would be fine with the standard 22.5dB gain setting given the 15 ohms output impedance and the 100 ohms loading.
james
K.H.
« Reply #21 on: 30 Apr 2011, 09:26 pm »
Is it possible to have this riaa installed in my BP26 and what will be the cost?
« Reply #22 on: 1 May 2011, 01:56 am »
Hi KH
Yes it can be installed - give Mike an email at [email protected]
James
K.H.
« Reply #23 on: 23 Jul 2011, 03:44 pm »
Hi KH
James
Hi James,
I did send Mike Pickett an e-mail yesterday 23.07.11, but have so far not had any answer.
I did also send him e-mails regarding some trouble with my 4BSST2 on 04.01, 28.01 and 17.03.11, but have never heard from him.
Sure you gave me the correct address?
Regards
Ketil
« Reply #24 on: 23 Jul 2011, 03:54 pm »
Hi James,
Regards
Ketil
Hi Ketil,
He is back on Monday I believe - I will forward this to him at home.
james
vegasdave
« Reply #25 on: 23 Jul 2011, 09:00 pm »
Hey James, is it possible to add the subsonic filter to the internal phono stage in the BP6? I ask this because I get woofer pumping on some records.
« Reply #26 on: 23 Jul 2011, 09:48 pm »
I do not think so but email Mike Pickett
James
vegasdave
« Reply #27 on: 23 Jul 2011, 10:11 pm »
Sounds good.
