0 Members and 1 Guest are viewing this topic. Read 35166 times.
The Pioneer's with Stable Platter design like the PD65 and 59 are good transports.
The NAD C565BEE is absolutely world class...it will floor you for $799 list or half that used. PS I've owned $15K players that didn't get it right the way this gem does:O)
As Phil A mentioned.... I've just bought the $500 Oppo BDP-93 for use specifically as a Universal, do-it-all, digital transport. It will drive my Zodiac+/Voltikus DAC. I should get it Friday and am curious to see how it performs in that role..?Cheers,Mark
The Audio-gd and NAD C565BEE new are getting a bit far a field of cheap and cheerful, the NAD C565BEE used at the $569 quoted is pushing it. Please remember the OP's target of $500 or less, with an emphasis on less.
The NAD C565BEE used is under $500. And it is 10X better than anything that I've seen listed in this thread.
I would look at the Onix cd88 on ac, that was a pretty good deal at $200.00
If you are going to use it with a DAC, consider getting something like - http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011002&p_id=5557&seq=1&format=2You can use one of the outputs of the BDP with an HDMI cable to the unit and a digital coax cable (or toslink) to the DAC and have the BDP-93 output PCM from SACD. Will beat many expensive SACD players. You can play with HDMI cables for sound and get a better power supply. Anything designed for a (5v) Squeezebox Touch power supply will work with the linked unit
