If you are in LA area, I can give you my Sony dvp7000, which is a great transport. The only problem with it is that I might have damaged something while trying to put the stock power cord back in. Even if it costs you $200 to fix it, it's still well worth it.
There is a local guy with a Cal Audio Labs CL-20 asking $425 for it. I know it got pretty good reviews back when it came out. What do you think about buying a used one now?
.....charges the iPod while in tray, basic iPod control from its remote control, SPDIF coaxial and optical outputs, rack mountable, even has video outputs.
JLM, do you know if it routes the digital out from the ipod through the coax spdif output?
i have an audio alchemy acd pro, cdp, w/pioneer stable-platter system. (the disc goes in upside-down.) supposed to be an excellent cdp in its own right; it is a killer transport. (i have only used it w/a dac.)there's one on agon, asking $449; it's still f/s after 32 days; you could likely get it for less... http://www.audiogon.com/cgi-bin/cls.pl?dgtlplay&1305772218doug s.
