0 Members and 1 Guest are viewing this topic. Read 71395 times.
How about a wireless dock?I was just about to buy an i-20 for my Ipod Touch (4th gen)until... I found that with Apple TV ($99, same as the i-20) I can stream wireless music @ 16/44 rez from the Itouch to Apple TV with AirPlay. The Apple TV connects to my DAC via toslink. This sounds like a pretty slick ipod connection to me. Navigating music with Itouch in hand is way better than sticking it in a dock and remoting it from across the room. It does however require a home wifi network. Anyone tried it?Russ
Yes, the remote is weak and its battery dies quickly. I have the dock at my listening chair with long cables so the crummy remote is not an issue.
I picked one of these up last week and am really enjoying it. Have a Ptech P3a in storage that I thought I'd compare to the i-20 DAC. Thought it would be plug and play but no sound The P3a has a green imput signal lit but no sound - any ideas?
Just to check - the volume isn't all the way down by any chance? (Volume does operate on the digital outs, I'm not sure how exactly.)
I've had this put aside for a while. My life seems to be plagued with hissy spitty little plugpacks (I mean audibly so) and the one that came with the i20 was another one. I finally got around to getting a couple of those Teradak linear power supplies and bam.
