Hi end streamers vs Squeezebox
0 Members and 1 Guest are viewing this topic. Read 4145 times.
ijbetts
« on: 13 Apr 2011, 06:29 pm »
Has anyone listened to the high end streamers from Linn (Akurate DS), Naim (HDX) or Cyrus (Stream XP) alongside Squeezebox?  If so do you think they offer a noticeable improvement?
I'm looking to build a system with a budget of about $15-20k (possibly a bit more) and want to make sure I invest enough in the source to warrant what I will be spending elsewhere.
  • Speakers....What Speakers ?
Re: Hi end streamers vs Squeezebox
« Reply #1 on: 14 Apr 2011, 04:13 am »
ijbetts...
Welcome to Audio Circle.... :thumb:
Since your question is about streamers vs Squeezebox , I'll be moving it to The Discless Circle where it can be addressed... :thumb:
geowak
« Reply #2 on: 14 Apr 2011, 06:52 am »
I do not know if this is helpful since i have not owned a HIGH END streamer and cannot comment about that but...
I have a Squeezebox and I have it running into a Benchmark DAC USB1. The benchmark bypasses any preamp as it acts as it's own preamp. With this configuration I am NOT using the internal DAC of the Squeezebox, I am using the Benchmark DAC.
When compared to a high end CD player like an Arcam, Rega and a Cambridge Audio, i could hear
no difference. My files are just AIFF.
The only problem I have ever had was a drop out of sound since my Squeezbox is wireless not wired and the stream was interrupted somehow. In that sense I like a dedicated CD player.
Also I have heard good things about the LOGITECH TRANSPORTER and you could connect any external DAC you like to it. There would be many opinions here as to what DAC would sound the best. Also the file type and manner by which you digitally copy or store seems to make a big difference. I have been satisfied with AIFF which is not compressed.
I have been happy with the SB and when I did have a problem with it, it was fixed by Logitech quickly and no charge. I have upgraded the power supply via Bolder Cable and it is pretty quiet.
pis99
« Reply #3 on: 14 Apr 2011, 07:11 am »
I do currently own two Logitech Transporters, one is unmodded and the other is Modwright modded Transporter. I also have a Linn Akurate DS operated through a dummy SB3 which I listen most of the time. I like the Linn Akurate the most but the Modwright Transporter does soemthing better if the speakers are different. Hope this help.
Wallacefl
« Reply #4 on: 14 Apr 2011, 11:48 pm »
I have a mix of the 2 above threads. I use the Squeezebox in one system thru the Benchmark DAC 1 pre and the other system uses a Modwright Transporter into a passive preamp then to the amp.. I realy like both...the Benchmark is a bit more resolved but the Modwright is more musical.
