AVA binding post specs, pls?
0 Members and 1 Guest are viewing this topic. Read 13161 times.
Wayner
Re: AVA binding post specs, pls?
« Reply #40 on: 28 Apr 2011, 08:59 pm »
Frank, he was asking if the power cord was wired backwards.
W
murf
  • Friends don't let friends apex early
« Reply #41 on: 28 Apr 2011, 09:00 pm »
Thanks Frank,
  I, for one, will never do this again.  How about the rest of you readers!!   :fishing:
Murf
Wayner
« Reply #42 on: 28 Apr 2011, 09:05 pm »
Oops, if it were wired backwards, it wouldn't even go to the switch (brain dead).
Wayner  :duh:
dlparker
  • Dave Parker - KC, MO
« Reply #43 on: 28 Apr 2011, 11:37 pm »
  Yo, old fashioned, my Gramps used to save old string....
Murf
A friend of mine who buys and resells all kinds of second hand items, while sorting through "stuff" from an estate, came across an envelope with little bits of string inside.  Hand written in pencil on the outside of the envelope was "pieces of string too short to save".
murf
« Reply #44 on: 29 Apr 2011, 02:18 pm »
Wayner  :duh:
Well Gosh, Wayner!
   I hope you weren't brain dead & got the wiring correct on MY amp!   :thumb:  (seems mighty good, though).
Murf
Brett Buck
« Reply #45 on: 29 Apr 2011, 05:17 pm »
   Even worse, all the cryogenically-treated electrons would be flushed out into the power grid, and not into the components! Or something.
     Brett
Wayner
« Reply #46 on: 29 Apr 2011, 06:20 pm »
I do not do any wiring. I am the mechanical guy (sheet metal).
Wayner  :D
CSI
« Reply #47 on: 15 May 2011, 06:03 pm »
Re: Binding post specs...long experience in the industry has me agreeing with Frank and others here about banana plugs being the best connector. I spent a few years as sales manager for a "high end" cable mfg. who always recommended bananas for practical reasons. Most audiophiles will change gear from time to time and bananas are a sure and easy way to facilitate hookups. As Frank notes, they are less likely to work loose and cause problems. They also offer substantially more contact area at the amp to cable interface.
murf
« Reply #48 on: 17 May 2011, 02:54 pm »
"...who always recommended bananas for practical reasons...They also offer substantially more contact area at the amp to cable interface."
How much contact area does the connection need?  Let's see, a speaker wire of maybe 16ga has a cross section area of...not too big.  So I need gonzo big-contact-area banana plugs?  If I am able to keep my binding posts tight on my spades or bare wire (some people can; some people do brake jobs on their cars), does the tight, totally vibration free connection make any sense in relation to sound quality?   :scratch:
(yes, I do think we are splitting hairs!  But can I hear a hair being split?)
Murf
CSI
« Reply #49 on: 17 May 2011, 04:12 pm »
If you can hear hairs being split then you can probably hear the difference. If not, then just relax and enjoy the music.
murf
« Reply #50 on: 17 May 2011, 04:29 pm »
Ouch!  Just got a haircut, and my ears are ringing!!!!  :no_hear:
Murf
charmerci
« Reply #51 on: 17 May 2011, 06:11 pm »
I think contact area is important. Ideally, I'd like to have my speaker cables soldered into my amp and speaker contacts. Why?
Years ago, I had 20 feet of speaker cable running from my amp - however, they were two 10 feet runs hand twisted together. Try that yourself and you will notice a definitive drop in the bass.
festuss
« Reply #52 on: 18 May 2011, 12:31 am »
 :duh: The wire dolts are truly entertaining.  Too many fancy full page ads in magazines, have people convinced of so much crap.  Dual banana plugs are the way to go. Of course you can hear the difference in 10 feet of wire.
