Mach2 Music, MBS and PI audio group have teamed up for a new product...
rollo
  • Rollo Audio Consulting -
  Dave sounds like a terrific addition to your excellent line of offereings. best of luck.
charles
dBe
    • PI audio group, LLC
charles
Thanks, Charles.  It really is good... I like it!!!  You should have seen the look on the Mach2 guys faces when they first heard it  :thumb:
Dave
jtwrace
    • TIPP YouTube Channel
Another thing to note is that this basic unit can be used for ANY 12V piece of battery powered gear to increase headroom and dynamics in the target component.
It reminds me of my little HD black box.  Remember?
I guess that you didn't make it to AXPONA, either, huh?
No sir!
dBe
No sir!
Oh, sure.  The MiniBUSS DC has been in the back of my mind since I built it.
All of this has been in the back of my mind since we started talking about Mac Mini power supplies a couple of years back.  That is how we met, IIRC.  I remember trying to wrap my head around the whole 18.5V issue with the MacMini back then and not being abe to arrive at a solution that I could live with.  The 2010 solved all of those problems being a 12V animal.  I'm sure the 2011 will be the same AFA power supplies go.  It will be interesting to see if Thunderbolt makes a sonic difference.  Everything else has that we have been screwing with from cables to OS, DACS, etc.  Whatever - you will love the Mini on battery power.  It is another level up in performance.
Come to think of it, you have been a great source of ideas for me.  Thanks for that, Jason  :thumb:  I love it when people make me think.   :D
Bummer about Atlanta for both of us.  I hope to see you there next year.  We really do need to sit down and brainstorm.  Email just doesn't cut it.
Dave
bahorn1
Sorry, man.  I thought that i made myself clear about the BatteryBUSS being a separate bit of gear from the battery.  My bad.
Another thing to note is that this basic unit can be used for ANY 12V piece of battery powered gear to increase headroom and dynamics in the target component.  Dodd battery power owners take note:  the BatteryBUSS will provide increased dynamic contrast, soundstage and flesh out the harmonic texture just a bit more.  The output impedance of the battery is a wee bit too high to deal with instantaneous current demands.  With the tube gear it is not as big of a difference as it is with SS gear, but it is there to be sure.
Thanks for the pictures, Rich.  You are a good man.
Dave
Hi Dave,
I have a Dodd Battery Pre.  How would I integrate the BatteryBUSS into the Dodd Battery Pre?
Doug
dBe
Hi Dave,
Doug
Doug, if you are talking about Gary's full size preamp with the batteries on board, I'm not sure.  I will have to talk to Gary to see if it is even feasable.  Now, if it is the Battery Buffer, you would just use it between your existing battery and the Buffer.  I would supply it with a mating PowerCon on the output cable.
Gary's battery powered gear is the biggest reason that I designed the BatteryBUSS in the first place.  He and I have been talking about this concept off and on for a couple of years.  About two years ago I approached him about doing a battery powered MacMini, but supplying 7A @ 18.5V was too much of a hassle.  Now with the plethora of battery powered gear on the market (especially DACs) including the 2010 MacMini that is happy on 12V, this was a no-brainer.
Dave
bahorn1
Dave
Hi Dave,
I have Gary's full-size battery pre-amp.  If the sound can be improved on this already great-sounding pre-amp, I'd be interested.  I just wasn't sure how the BatteryBUSS would work with the Dodd since the batteries are already onboard.
Doug
dBe
Hi Dave,
Doug
Doug, I'll find out from Gary if we can do this.  Perhaps a battery I/O on the back of the preamp and matching cabling is all it will take, or something that he can mount internally if there is enough room.  I have been waiting to hear from him to find out when he will be back in shape to work on new things.
I'll be in touch.
Dave
praedet
Dave,
I pm'ed you about stuff, but this might negate that :duh:
I have a Battery power supply that has an input for the charger, and 4 outputs for components.  Long term these 4 will be...
1. Dodd Audio Battery Buffer (Already running on the supply)
2. Class D Audio SDS-254 Amp (Will be running on this supply soon)
3. Alix PC Linux Music Server (Currently building the cord to run this, requires 7-20V)
4. TPA Buffalo 32s DAC (Not even built yet)
I want to have as clean and dynamic a power source as possible, so what do I need?  4 BatteryBusses?  The Dodd and Amp have Neutrik inputs, and the Battery PS has all Neutrik Powercons...
If this would be easier over the phone, let me know ;)
Ted
ebag4
Dave,
Ted
I would like to see the answer to this question as I have a similar setup.
Best,
Ed
Rclark
Is this something that would improve the battery supply on my Two.2? It, of course, uses two 12v, 5 amp batteries in series for around 28 volts on constant charge.
dBe
It will make it punchier and quieter.  The unit is good to ~32VDC (35V caps inside)  I can build with higher voltage caps, but there is really no reason to do so.  The caps I use are tested to 2X voltage.
Remember that it has two other outputs as standard build that can be used for HDD, DACs - all sorts of things.
Dave
Rclark
So it could run both my amp and the smaller battery on my Warpspeed? How much improvement do users typically report? I know your other busses are very highly regarded, obviously, but wasn't aware of this one.
dBe
You would think I died or something.    :o
The BatteryBUSS is like my other products in that it can be configured to handle quite a range of outputs.  Remember, this is a 12-32V (depending upon DC voltage input) noise reduction unit that will provide additional regulated 5V sources for computer based audio gear.  It has a wide range of applications and can provide punchy power to just about any DC powered audio gear, depending upon configuration.  "How much improvement" is not easily quantifiable.  It eliminates the sulphation noise in AGM batteries and has a very low output impedance, which batteries do not have.
Dave
Rclark
And how exactly does that help? Thank you, I'm really interested in learning more about these.
praedet
Here is my review from the BB thread...
Well, I can now weigh in on the BatteryBUSS (BB) as I have had mine for a while, and a recent addition showed how truly awesome it is :icon_twisted:
First, I would like to thank Dave for allowing me to be part of the group buy.  Besides that, the customer service and knowledge that he is willing to share are truly unusual these days.  My BB is slightly special in that it actually has 5 outputs.  3 Regular XLRs and 2 minis.  I also got 4 assembled cables and 2 for me to assemble in the future as required.  The system this is going in is as follows:
PC Engine Alix Linux based music Server (Battery Power)
V-Link USB-SPDIF (Originally USB Powered, now battery Power)
Modified Lite Audio DAC-60 (AC)
Dodd Audio Tube Buffer (Battery Power)
Class-D SDS-254 (Battery Power)
Polk Audio LSi9s modded to the hilt by the Ninja
Kinetik HCA 1400 SLA Batter in a Battery Box with 4 outputs and 1 input
Cabling is mostly DIY VH Audio Silver RCAs and then a braided DIY Speaker cable made from Electra Cable Wire
I will discuss future changes later on, but that is the system as it sits now.  So, before I was running everything that was battery powered off the battery box with no filtering or cleaning at all.  I started with the V-Link powered from the Alix, but now I have a single cable from the battery box to the BB, and then 4 cables going to the various equipment.  Initially, while the V-Link was powered by the Alix, there was an improvement with the BB, but not dramatic.  The noise floor went down slightly, and instruments seemed a little more separate, but overall it was not much of a change.  I was able to truly try all the possibilities as I had all the outputs on my battery box, plus I had an extra SLA battery and charger that I could even put something on a second battery.  I figured out that the system sounded it’s best with everything fed through the BatteryBUSS.  But, with the Dodd at listening volume and no music, I had an oscillating noise that was audible at about 1-2 feet from the speakers and would not go away.  It was quieter when all equipment was running off the BB, but it was there.  It was loud enough to hear anywhere in the room with the volume pegged.  Moreover, it seemed to be creating an “edge” to the music with was more noticeable on some songs than others. (Everything is flac and cd quality atleast, with some high resolution thrown in)  This is the point when I started e-mailing Dave questions.  And, that is when he offered to let me try a new cable he has been cooking up.  So, I of course bit :icon_twisted:
This cable takes the data from the Alix and routes it to the V-Link, but the power for the V-Link comes from the BatteryBUSS.  Literally, from moment one with the cable added I was floored.  Here is the actual e-mail I sent to Dave after hearing the cable.
“Before, at listening volume (Dodd Buffer at about 9 o'clock), the digital oscillating noise was noticeable if the music was stopped and I got my ear within about 2 feet from the speaker.  When the music was playing, there was an "edge" that I couldn't identify.  At full volume and no music, the noise was noticeable anywhere in the room...
Now, the noise is virtually gone.  At listening volume, it is not present with my ear against the speaker.  At full volume, it is BARELY there, again with my ear against the speaker.  The "edge" is gone in music.
Now, the superlatives.
Honestly, I was not prepared for the change that is there.  And this is with NO TIME on the cord.  The music is just there. It floats in the room with nothing to make you think it came from a computer.  The problems I had with the Alix set-up are now gone.  This is atleast as big a change as the BatteryBuss itself made.  Well, I say that with the qualifier of the V-Link USB power bringing the whole set-up down.”
Truly, everything I hoped this set-up would be, it is.  There is no noise.  There is only music.  The music is there, and it seems ULTRA realistic.  This is especially true of good Live recordings.  One of my favorite to listen to (as a former drummer) is the 3rd song on the 2nd disk from the Dave Matthews Band album “The Best of What’s Around Volume 1”.  The song is “Say Goodbye” and starts with a very fun Drum solo that really highlights the great recording they did of the band.  You get to hear where each piece of Carter’s set is on the stage, and it sounds like you are there.  Then you have a flute solo which begins.  When it is playing you can tell where the flutist is on the stage, and which direction he is facing.  Overall, it is a wonderful test/show song.  So, before the BatteryBUSS and USB cord, this song was very fun, but it had the small “edge” to it, and the soundstage was compressed.  Now the soundstage is well beyond the speakers and is quite large front to back as well.  The only way to describe it is to say that it feels like I am there, watching live.  Hope that makes sense…
Anyway, the BatteryBUSS is amazing, the new USB cable is amazing, and Dave is an all around great guy 8)
Ted
Rclark
Oh thank you for that!  :green:
Would have come back to check sooner but responses are a bit slow on this board. I think this will be something I might want to add in Feb. I have my speaker mod very soon, and I just made a deal on Pez's VMPS subs. They will need some work, amp, eq.. But after that.
 any chance for a tour?
